주요 콘텐츠로 건너뛰기
Felt Z85 Brake Pad Replacement
필요한 것
  1. Felt Z85 Brake Pad Replacement, Remove Wheel: 1 단계, 이미지 1/3 Felt Z85 Brake Pad Replacement, Remove Wheel: 1 단계, 이미지 2/3 Felt Z85 Brake Pad Replacement, Remove Wheel: 1 단계, 이미지 3/3
    • Pull up on brake-release lever to spread pads for easy access.
    • Release lever on the right side of the wheel.
    • Loosen left nut on wheel until wheel comes free.
  2. Felt Z85 Brake Pad Replacement, Remove Pad(s): 2 단계, 이미지 1/3 Felt Z85 Brake Pad Replacement, Remove Pad(s): 2 단계, 이미지 2/3 Felt Z85 Brake Pad Replacement, Remove Pad(s): 2 단계, 이미지 3/3
    • Locate Brake Caliper.
    • Use 4.0 mm allen key to remove main bolt.
    • Rotate counterclockwise to loosen.
    • Be careful not to lose both the washer and spacer found in-between the bolt and the brake pad mounting hole.
    • Repeat step 2 to remove the pad on the other side.
  3. Felt Z85 Brake Pad Replacement, Collecting parts (reinstall): 3 단계, 이미지 1/2 Felt Z85 Brake Pad Replacement, Collecting parts (reinstall): 3 단계, 이미지 2/2
    • Brake Pad: The item being replaced.
    • Spacer: This item will be reused.
    • Washer: This item will be reused.
    • 4 mm hex bolt.
    • Note order of mounting hardware for reinstall.
결론
Ryan Marschall
회원 가입일: 10/11/14
123 평판
안내서 1개 작성함
USF Tampa, Team 1-21, Donnelly Fall 2014 USF Tampa, Team 1-21, Donnelly Fall 2014 회원
USFT-DONNELLY-F14S1G21
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 12
전체 시간: 1,028
