주요 콘텐츠로 건너뛰기
Fender '65 Tube Amp Speaker Replacement
필요한 것
  1. Fender '65 Tube Amp Speaker Replacement, Speaker: 1 단계, 이미지 1/1
    • Lay the amplifier face-down.
  2. Fender '65 Tube Amp Speaker Replacement: 2 단계, 이미지 1/1
    • Remove both back plates by unscrewing eight 1.2 mm screws with a Phillips #1 screwdriver.
    • Keep track of the eyelets.
  3. Fender '65 Tube Amp Speaker Replacement: 3 단계, 이미지 1/2 Fender '65 Tube Amp Speaker Replacement: 3 단계, 이미지 2/2
    • Remove the power stage vacuum tubes. Gently pull out the tube while simultaneously pressing down the metal holder.
  4. Fender '65 Tube Amp Speaker Replacement: 4 단계, 이미지 1/3 Fender '65 Tube Amp Speaker Replacement: 4 단계, 이미지 2/3 Fender '65 Tube Amp Speaker Replacement: 4 단계, 이미지 3/3
    • Remove the positive and negative speaker connections and label them accordingly with a marker and painter's tape.
  5. Fender '65 Tube Amp Speaker Replacement: 5 단계, 이미지 1/1
    • Remove the other side of the speaker connection from the internal speaker input jack.
  6. Fender '65 Tube Amp Speaker Replacement: 6 단계, 이미지 1/3 Fender '65 Tube Amp Speaker Replacement: 6 단계, 이미지 2/3 Fender '65 Tube Amp Speaker Replacement: 6 단계, 이미지 3/3
    • Remove the reverb tank by unscrewing two 1.2 mm screws with a Phillips #1 screwdriver and unfastening the velcro by hand.
    • The wire must stay connected.
  7. Fender '65 Tube Amp Speaker Replacement: 7 단계, 이미지 1/3 Fender '65 Tube Amp Speaker Replacement: 7 단계, 이미지 2/3 Fender '65 Tube Amp Speaker Replacement: 7 단계, 이미지 3/3
    • Remove the speaker by unscrewing four 1.2 mm screws with a Phillips #1 screwdriver.
    • Potential for device damage: Do not touch the front of the speaker when handling.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 4
전체 시간: 60
