주요 콘텐츠로 건너뛰기
Fender 65 Twin Reverb Power Tube Replacement
필요한 것
  1. Fender 65 Twin Reverb Power Tube Replacement, Power Tube: 1 단계, 이미지 1/3 Fender 65 Twin Reverb Power Tube Replacement, Power Tube: 1 단계, 이미지 2/3 Fender 65 Twin Reverb Power Tube Replacement, Power Tube: 1 단계, 이미지 3/3
    • Make sure to unplug the power cord!
    • Take off the back panel by unscrewing the four Phillips head screws on the back of the amplifier. You will find the four power vacuum tubes are the largest ones on the left side.
    • Keep the screws in a safe place and mark what part they are for.
  2. Fender 65 Twin Reverb Power Tube Replacement: 2 단계, 이미지 1/3 Fender 65 Twin Reverb Power Tube Replacement: 2 단계, 이미지 2/3 Fender 65 Twin Reverb Power Tube Replacement: 2 단계, 이미지 3/3
    • Using the cloth, you can then remove a tube by pressing up on the two metal flaps near the top of the tubes, while lightly pulling the tube down.
  3. Fender 65 Twin Reverb Power Tube Replacement: 3 단계, 이미지 1/2 Fender 65 Twin Reverb Power Tube Replacement: 3 단계, 이미지 2/2
    • Check the tube for any cracks in the glass. also check to make sure the filaments are not burnt out.
    • A new or working tube should look like the one in the picture, no cracks or broken filaments.
    • If you buy a replacement tube, it is recommended that you buy one that is the same as the original and made by the same company.
  4. Fender 65 Twin Reverb Power Tube Replacement: 4 단계, 이미지 1/2 Fender 65 Twin Reverb Power Tube Replacement: 4 단계, 이미지 2/2
    • Take the new replacement tube (or your old one if it is still working) and insert it into the appropriate slot, pressing lightly but firmly. Make sure that the prongs at the end line up with the correct holes.
    • You should hear a click when the tube is secured in place.
    • Repeat these steps with the other three tubes if necessary.
결승점
다른 2명이 해당 안내서를 완성하였습니다.
Laura Kawashiri
회원 가입일: 01/22/14
276 평판
안내서 1개 작성함
Cal Poly, Team 9-27, Maness Winter 2014 Cal Poly, Team 9-27, Maness Winter 2014 회원
CPSU-MANESS-W14S9G27
5 회원들
안내서 7개 작성하였습니다
댓글 한 개
What about Bias adjustment??
steffengronlikaroliussen - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 14
전체 시간: 5,476
