주요 콘텐츠로 건너뛰기
Fender 65 Twin Reverb Preamp Tube Replacement
필요한 것
  1. Fender 65 Twin Reverb Preamp Tube Replacement, Preamp Tube: 1 단계, 이미지 1/3 Fender 65 Twin Reverb Preamp Tube Replacement, Preamp Tube: 1 단계, 이미지 2/3 Fender 65 Twin Reverb Preamp Tube Replacement, Preamp Tube: 1 단계, 이미지 3/3
    • Make sure to unplug the power cord!
    • Take off the back panel by unscrewing the four Phillips head screws on the back of the amplifier. You will find the six preamp tubes are the smaller ones on the right. (The picture only shows five of the six.)
    • Keep the screws in a safe place and mark what part they are for.
  2. Fender 65 Twin Reverb Preamp Tube Replacement: 2 단계, 이미지 1/2 Fender 65 Twin Reverb Preamp Tube Replacement: 2 단계, 이미지 2/2
    • Remove the metal casing by gently pressing up against the case and twisting to the right.
  3. Fender 65 Twin Reverb Preamp Tube Replacement: 3 단계, 이미지 1/2 Fender 65 Twin Reverb Preamp Tube Replacement: 3 단계, 이미지 2/2
    • Using the cloth, remove one tube by firmly grasping and gently pulling downwards.
    • Pulling directly downwards prevents damage to the hookup prongs at the bottom of the tube.
  4. Fender 65 Twin Reverb Preamp Tube Replacement: 4 단계, 이미지 1/1
    • Check the tube for any cracks in the glass. Also check to make sure the filaments are not burnt out.
    • If the tube is still functioning or to insert the replacement or, proceed to step five.
  5. Fender 65 Twin Reverb Preamp Tube Replacement: 5 단계, 이미지 1/2 Fender 65 Twin Reverb Preamp Tube Replacement: 5 단계, 이미지 2/2
    • Take the new replacement tube and insert it into the appropriate slot, making sure that the prongs at the end line up with the correct holes.
    • You should hear a click when the tube is secured in place.
    • Repeat these steps with the other three tubes if necessary.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Andrew Exton
회원 가입일: 01/26/14
141 평판
안내서 1개 작성함
Cal Poly, Team 9-27, Maness Winter 2014 Cal Poly, Team 9-27, Maness Winter 2014 회원
CPSU-MANESS-W14S9G27
5 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 10
30일 전: 31
전체 시간: 6,258
