주요 콘텐츠로 건너뛰기
Fender Frontman 15r Reverb Tank Replacement
필요한 것
  1. Fender Frontman 15r Reverb Tank Replacement, Remove the Back Plate: 1 단계, 이미지 1/2 Fender Frontman 15r Reverb Tank Replacement, Remove the Back Plate: 1 단계, 이미지 2/2
    • Remove 6 Phillips screws securing the back plate.
    • Lift the back panel out of the amp.
    • Gently pry with a flathead screwdriver or other tool to release the back panel if it's stuck.
    • Be careful not to pull out the wires connected to the power converter.
  2. Fender Frontman 15r Reverb Tank Replacement, Free the Reverb Tank: 2 단계, 이미지 1/2 Fender Frontman 15r Reverb Tank Replacement, Free the Reverb Tank: 2 단계, 이미지 2/2
    • Saw the adhesive from in between the reverb tank and the cabinet until the reverb tank is released.
  3. Fender Frontman 15r Reverb Tank Replacement, Free the Connecting Wires: 3 단계, 이미지 1/1
    • Use wire cutters to remove the zip tie fastening the wires to the speaker.
  4. Fender Frontman 15r Reverb Tank Replacement, Disconnect Wires from Motherboard: 4 단계, 이미지 1/2 Fender Frontman 15r Reverb Tank Replacement, Disconnect Wires from Motherboard: 4 단계, 이미지 2/2
    • Unplug the wires leading from the reverb tank to the motherboard.
    • Notice they are plugged in where the motherboard is labeled "reverb only."
    What are these plug ends or leads called? Is there an RCA adapter/converter for them?
    John Ender - 답글
  5. Fender Frontman 15r Reverb Tank Replacement, Remove Reverb Tank: 5 단계, 이미지 1/1
    • Remove the reverb tank.
    what if I wanted to upgrade to gen 1 replacement like this one
    https://www.amplifiedparts.com/products/...
    John Ender - 답글
  6. Fender Frontman 15r Reverb Tank Replacement, Install New Reverb Tank: 6 단계, 이미지 1/1
    • Glue the new reverb tank into place following the directions provided with the glue or epoxy of your choice.
  7. Fender Frontman 15r Reverb Tank Replacement, Test the New Reverb Tank: 7 단계, 이미지 1/1
    • Reconnect the wires and test the new reverb tank ensuring the effect properly matches the knob setting.
결론
Sam Omiotek
회원 가입일: 02/25/19
72,562 평판
안내서 288개 작성하였습니다
댓글 2개
I guess there is 2 versions of this amp the one in this video this version of the tank has 3 springs; this looks like 2…
Wonder which one was the newer version?
https://www.youtube.com/watch?v=o856fDGI...
John Ender - 답글
Interesting! I wouldn’t know which is the newer version, but the one in the YouTube video does look like it has higher quality parts…
Sam Omiotek -
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 11
30일 전: 47
전체 시간: 2,335
