주요 콘텐츠로 건너뛰기
Fender Frontman 15r Speaker Replacement
필요한 것
  1. Fender Frontman 15r Speaker Replacement, Back panel: 1 단계, 이미지 1/1
    • Be sure to unplug the device before proceeding.
    • Use a Phillips #0 screwdriver to remove the four 21.7mm screws holding the back panel to the frame.
  2. Fender Frontman 15r Speaker Replacement: 2 단계, 이미지 1/1
    • Once the screws are out, use a plastic opening tool or spudger to pry the top of the back panel open. There may be some resistance, but it will eventually pry loose.
  3. Fender Frontman 15r Speaker Replacement: 3 단계, 이미지 1/1
    • Once the top is separated, use your hand to remove the back panel from the unit.
  4. Fender Frontman 15r Speaker Replacement, Speaker: 4 단계, 이미지 1/1
    • Using tape or a post-it, label the input and output wires on the reverb. Remove these wires from the box.
  5. Fender Frontman 15r Speaker Replacement: 5 단계, 이미지 1/1
    • Remove the two female connection terminals from the speaker terminals.
  6. Fender Frontman 15r Speaker Replacement: 6 단계, 이미지 1/1
    • Use a Philips #1 screwdriver to remove the four 21.9 mm Phillips screws from the perimeter of the speaker.
  7. Fender Frontman 15r Speaker Replacement: 7 단계, 이미지 1/2 Fender Frontman 15r Speaker Replacement: 7 단계, 이미지 2/2
    • Gently remove the speaker.
결론
To install the new speaker, follow the instructions given in reverse.
다른 한 분이 해당 안내서를 완성하였습니다.
Stephen Figueira
회원 가입일: 10/04/12
131 평판
안내서 3개 작성하였습니다
Cal Poly, Team 24-30, Regan Fall 2012 Cal Poly, Team 24-30, Regan Fall 2012 회원
CPSU-REGAN-F12S24G30
5 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 45
전체 시간: 8,275
