주요 콘텐츠로 건너뛰기
Fender Jazz Bass Strings Replacement
필요한 것
  1. Fender Jazz Bass Strings Replacement, Strings: 1 단계, 이미지 1/1
    • Loosen the strings by turning the tuning pegs.
  2. Fender Jazz Bass Strings Replacement: 2 단계, 이미지 1/1
    • Once the strings are loose, remove them from the tuning pegs.
    • If you prefer, you can also cut the strings off.
  3. Fender Jazz Bass Strings Replacement: 3 단계, 이미지 1/2 Fender Jazz Bass Strings Replacement: 3 단계, 이미지 2/2
    • Reach under the bridge to pull out the end of each string.
  4. Fender Jazz Bass Strings Replacement: 4 단계, 이미지 1/2 Fender Jazz Bass Strings Replacement: 4 단계, 이미지 2/2
    • Insert the end of the string with no knob on the bottom through the bridge first.
    • Pull each string through to the top of the neck.
  5. Fender Jazz Bass Strings Replacement: 5 단계, 이미지 1/1
    • Insert the strings into the indentations on the nut.
    • Wrap the strings around the tuning pegs about two times.
  6. Fender Jazz Bass Strings Replacement: 6 단계, 이미지 1/2 Fender Jazz Bass Strings Replacement: 6 단계, 이미지 2/2
    • Tighten the tuning pegs until the bass is in tune.
    • The standard tuning for a bass is E A D G.
    • You will have excess string hanging off the pegs of the bass.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
Matthew Caldera
회원 가입일: 01/24/22
133 평판
안내서 1개 작성함
CSU Los Angeles, Team 1-1, Briggs Spring 2022 CSU Los Angeles, Team 1-1, Briggs Spring 2022 회원
CSULA-BRIGGS-S22S1G1
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 27
전체 시간: 514
