주요 콘텐츠로 건너뛰기
Bomann DB 774CB Iron
필요한 것
  1. Bomann DB 774CB Iron, Startup: 1 단계, 이미지 1/1
    • Locate and extract the small plug (circled in the photo) and remove the screw hidden underneath.
    • Unscrew and remove the back plate.
  2. Bomann DB 774CB Iron, Undressing the handle: 2 단계, 이미지 1/3 Bomann DB 774CB Iron, Undressing the handle: 2 단계, 이미지 2/3 Bomann DB 774CB Iron, Undressing the handle: 2 단계, 이미지 3/3
    • Unclip the top of the handle from the back (clips circled in the photos).
    • Unclip the top of the handle from the front (clips circled in the photo). Be careful not to break (like us) the steam nozzle!
    • Pull out the steam control knobs.
    • Carefully "tear" the temperature adjustment knob.
  3. Bomann DB 774CB Iron, Stripping of the sole: 3 단계, 이미지 1/2 Bomann DB 774CB Iron, Stripping of the sole: 3 단계, 이미지 2/2
    • Remove the screws and remove the plastic shell.
    • Unscrew the screws and remove the base cover.
  4. Bomann DB 774CB Iron, Breakdowns: 4 단계, 이미지 1/1
    • Two different failures already observed:
    • Spacer (circled) which had come out of its housing following a fall of the iron!
    • Small foreign body that got stuck between the two contacts (circled).
    • Be careful not to turn the temperature adjustment screw (arrow) located in the control rod. Its readjustment is quite tedious, by mistake and trials!
결론
Putting each screw back in its place is no problem.
다른 6명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
fr en
100%
HelloMacOS님은 저희가 세상을 수리하는데 동참하신 분입니다! 기여하시겠습니까?
번역 시작하기 ›
Louis Possoz
회원 가입일: 01/10/15
435 평판
안내서 3개 작성하였습니다
Repair Café Louvain-la-Neuve Repair Café Louvain-la-Neuve 회원
Community
2 회원들
안내서 6개 작성하였습니다
댓글 한 개
Do you instructions in English
Nur Haque - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 5
30일 전: 30
전체 시간: 2,901
