주요 콘텐츠로 건너뛰기
Fiat 500 Abarth Taillight Replacement
필요한 것
  1. Fiat 500 Abarth Taillight Replacement, Fiat 500 Abarth Taillight: 1 단계, 이미지 1/2 Fiat 500 Abarth Taillight Replacement, Fiat 500 Abarth Taillight: 1 단계, 이미지 2/2
    • Remove the two 10 mm bolts to the side of the taillight.
  2. Fiat 500 Abarth Taillight Replacement: 2 단계, 이미지 1/2 Fiat 500 Abarth Taillight Replacement: 2 단계, 이미지 2/2
    • Using a pry tool or something flat, carefully get in-between the light and the car and pry the light off.
    • The light still has cable connections to the car body, so be sure not to rip these during removal.
  3. Fiat 500 Abarth Taillight Replacement: 3 단계, 이미지 1/3 Fiat 500 Abarth Taillight Replacement: 3 단계, 이미지 2/3 Fiat 500 Abarth Taillight Replacement: 3 단계, 이미지 3/3
    • There are several little clips on this module.
    • Unclip the clips on the back of the light and remove the panel.
  4. Fiat 500 Abarth Taillight Replacement: 4 단계, 이미지 1/3 Fiat 500 Abarth Taillight Replacement: 4 단계, 이미지 2/3 Fiat 500 Abarth Taillight Replacement: 4 단계, 이미지 3/3
    • Remove the burnt out bulb by pulling it out from the panel.
  5. Fiat 500 Abarth Taillight Replacement: 5 단계, 이미지 1/3 Fiat 500 Abarth Taillight Replacement: 5 단계, 이미지 2/3 Fiat 500 Abarth Taillight Replacement: 5 단계, 이미지 3/3
    • Clip the panel back onto the light and put it back into the frame of the car.
    • Replace the two bolts with a 10 mm socket.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Tim Polishchuk
회원 가입일: 01/11/21
152 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 8
7일 전: 62
30일 전: 258
전체 시간: 10,479
