주요 콘텐츠로 건너뛰기
Filter Housing Replacement for GE Refrigerators model GSS25KSW / GSF25KGW
필요한 것
  1. Filter Housing Replacement for GE Refrigerators model GSS25KSW / GSF25KGW, Filter Housing for GE Refrigerators: 1 단계, 이미지 1/1
    • Disconnect the electric plug from the wall.
  2. Filter Housing Replacement for GE Refrigerators model GSS25KSW / GSF25KGW: 2 단계, 이미지 1/1
    • Turn off or push down off water main valve from the wall.
  3. Filter Housing Replacement for GE Refrigerators model GSS25KSW / GSF25KGW: 3 단계, 이미지 1/3 Filter Housing Replacement for GE Refrigerators model GSS25KSW / GSF25KGW: 3 단계, 이미지 2/3 Filter Housing Replacement for GE Refrigerators model GSS25KSW / GSF25KGW: 3 단계, 이미지 3/3
    • Remove the back panel with 6 screws from the back panel using a 8 mm nut driver.
  4. Filter Housing Replacement for GE Refrigerators model GSS25KSW / GSF25KGW: 4 단계, 이미지 1/2 Filter Housing Replacement for GE Refrigerators model GSS25KSW / GSF25KGW: 4 단계, 이미지 2/2
    • Disconnect the water supplied line from the refrigerator using two 13 mm open-end wrenches.
    • Use a little bucket to receive the water from the water lines.
  5. Filter Housing Replacement for GE Refrigerators model GSS25KSW / GSF25KGW: 5 단계, 이미지 1/1
    • Disconnect the water line from the water inlet valve using and open-end wrench size 15mm
  6. Filter Housing Replacement for GE Refrigerators model GSS25KSW / GSF25KGW: 6 단계, 이미지 1/2 Filter Housing Replacement for GE Refrigerators model GSS25KSW / GSF25KGW: 6 단계, 이미지 2/2
    • Disconnect the water line cover removing 2 screws using a 7 mm nut driver.
    • Pull up the gum seal compound.
  7. Filter Housing Replacement for GE Refrigerators model GSS25KSW / GSF25KGW: 7 단계, 이미지 1/1
    • Push the left side of the filter cover and pull it straight out.
  8. Filter Housing Replacement for GE Refrigerators model GSS25KSW / GSF25KGW: 8 단계, 이미지 1/2 Filter Housing Replacement for GE Refrigerators model GSS25KSW / GSF25KGW: 8 단계, 이미지 2/2
    • Remove the 2 screws on top of the housing using 7 mm nut driver.
    • Pull the housing and filter out slowly.
    • Remove the filter by turn it counterclockwise
결론
Giancarlo Marruffo
회원 가입일: 09/18/16
2 평판
안내서 1개 작성함
Pasco Hernando, Team 5-1, Prince Fall 2016 Pasco Hernando, Team 5-1, Prince Fall 2016 회원
PHSC-PRINCE-F16S5G1
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 21
전체 시간: 2,071
