주요 콘텐츠로 건너뛰기
Firmware update or recovery - PC (All models)
필요한 것
  1. Firmware update or recovery - PC (All models), Plug the controller in: 1 단계, 이미지 1개 중 1개
    • Connect the controller using a USB-C OR MicroUSB cable. Plug the controller into a USB port on your PC.
    • Bluetooth firmware updates are not supported.
  2. Firmware update or recovery - PC (All models), Download the Xbox Accessories app.: 2 단계, 이미지 2개 중 1개 Firmware update or recovery - PC (All models), Download the Xbox Accessories app.: 2 단계, 이미지 2개 중 2개
    • Download the Xbox Accessories app from Microsoft Store using this link.
    • After it has finished downloading, you can launch it either straight off the app's page or from your Start Menu.
  3. Firmware update or recovery - PC (All models), Prepare the app for the firmware update: 3 단계, 이미지 2개 중 1개 Firmware update or recovery - PC (All models), Prepare the app for the firmware update: 3 단계, 이미지 2개 중 2개
    • After you launch the app and it finishes loading, the controller should show up like on the first photo.
    • Click on the three dots under the Configure button.
    • If the button over the Buzz/Vibrate this controller says No update available, your controller is already up to date and the guide ends here.
  4. Firmware update or recovery - PC (All models), Update the firmware: 4 단계, 이미지 2개 중 1개 Firmware update or recovery - PC (All models), Update the firmware: 4 단계, 이미지 2개 중 2개
    • Press the Continue button and wait for the process to finish.
    • In most cases, the firmware can be recovered, but be careful not to disconnect the controller during the update. Any loss of connection, be it disconnecting or PC power loss may damage the controller beyond repair.
    • After the update, press Close. Your controller is now up to date and should be fully usable with your PC, Xbox One or Series S/X consoles.
결승점
다른 6명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
SojerManLan
회원 가입일: 07/07/21
253 평판
안내서 1개를 작성함
1가이드 댓글
Use this video if you need to undo anything.
Revert Firmware
go away - 답글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 31
지난 30일: 149
전체 시간: 6,064
