소개
This FastFix is provided so that you may be able to replace a broken FirsTime Wall Clock due to a faulty movement mechanism. This is helpful so you won’t have to spend money on replacing this item. It is a short and easy fix!
필요한 것
Using a Phillips #1 screwdriver, remove all four screws on the back of the clock.
다른 18명이 해당 안내서를 완성하였습니다.
댓글 5개
Is there a you tube showing these steps?
Thank you! there was one tricky thing—the parts I got in the order did not match what I took off, so I had to reconfigure it a bit per new instructions that came with the parts. But I figured it out! Thank you for this instruction.
Excellent illustrations!!!
there seem to be 2 projections keeping the back & glass together.
I don't want to break them.
