주요 콘텐츠로 건너뛰기
FirsTime Wall Clock Movemement Mechanism Replacement
필요한 것
  1. FirsTime Wall Clock Movemement Mechanism  Replacement, Movemement Mechanism: 1 단계, 이미지 2개 중 1개 FirsTime Wall Clock Movemement Mechanism  Replacement, Movemement Mechanism: 1 단계, 이미지 2개 중 2개
    • Using a Phillips #1 screwdriver, remove all four screws on the back of the clock.
  2. FirsTime Wall Clock Movemement Mechanism  Replacement: 2 단계, 이미지 1개 중 1개
    • Once screws are removed, simply remove the glass lens covering the display of the clock by lifting it with your hands.
  3. FirsTime Wall Clock Movemement Mechanism  Replacement: 3 단계, 이미지 2개 중 1개 FirsTime Wall Clock Movemement Mechanism  Replacement: 3 단계, 이미지 2개 중 2개
    • Turn the display face up.
    • Use needle nose pliers to pull off the 'second' hand.
  4. FirsTime Wall Clock Movemement Mechanism  Replacement: 4 단계, 이미지 2개 중 1개 FirsTime Wall Clock Movemement Mechanism  Replacement: 4 단계, 이미지 2개 중 2개
    • Use needle nose pliers to remove the 'minute' hand.
    • Then use needle nose pliers to remove the 'hour' hand.
  5. FirsTime Wall Clock Movemement Mechanism  Replacement: 5 단계, 이미지 1개 중 1개
    • Once all hands are removed, use a 7/16-inch wrench to unscrew, in counter clockwise direction, the threaded nut in the center of the clock.
    • Removing the threaded nut is what allows the movement mechanism to be removed from the clock.
  6. FirsTime Wall Clock Movemement Mechanism  Replacement: 6 단계, 이미지 2개 중 1개 FirsTime Wall Clock Movemement Mechanism  Replacement: 6 단계, 이미지 2개 중 2개
    • Lift the washer underneath the nut with your fingers.
  7. FirsTime Wall Clock Movemement Mechanism  Replacement: 7 단계, 이미지 1개 중 1개
    • Now you may remove the display of the clock from your malfunctioning movement mechanism.
결론
다른 25명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Samid Rehan
회원 가입일: 02/20/19
723 평판
안내서 1개를 작성함
7가이드 댓글
Is there a you tube showing these steps?
Patricia Ander - 답글
Thank you! there was one tricky thing—the parts I got in the order did not match what I took off, so I had to reconfigure it a bit per new instructions that came with the parts. But I figured it out! Thank you for this instruction.
Leslie Benitez - 답글
Excellent illustrations!!!
KO SAMUEL TAK SHUN - 답글
there seem to be 2 projections keeping the back & glass together.
I don't want to break them.
Marcia Kaminski - 답글
Where can I buy the exact clock?
Barb - 답글
댓글 쓰기
조회 통계:
지난 24시간: 9
지난 7일: 40
지난 30일: 183
전체 시간: 12,572
