주요 콘텐츠로 건너뛰기
First Act MA2039 Battery Replacement
필요한 것
  1. First Act MA2039 Battery Replacement, Battery: 1 단계, 이미지 1/3 First Act MA2039 Battery Replacement, Battery: 1 단계, 이미지 2/3 First Act MA2039 Battery Replacement, Battery: 1 단계, 이미지 3/3
    • Press the bottom tab and lift the lid that is marked "9V Battery"
    • Open the lids of both battery cartridges, use a Spudger to lift the 9-volt battery out.
    • Disconnect the attached 9-volt battery from the positive and negative terminal connections to prepare for replacement.
  2. First Act MA2039 Battery Replacement: 2 단계, 이미지 1/3 First Act MA2039 Battery Replacement: 2 단계, 이미지 2/3 First Act MA2039 Battery Replacement: 2 단계, 이미지 3/3
    • Insert a new, fully-charged 9-volt battery to the terminal connections.
    • Link the positive terminal (+) of the 9-volt battery to the positive connection.
    • Link the negative terminal (-) of the 9-volt battery to the negative connection.
    • Repeat the process for the 2nd 9-volt battery in the neighboring cartridge.
  3. First Act MA2039 Battery Replacement: 3 단계, 이미지 1/2 First Act MA2039 Battery Replacement: 3 단계, 이미지 2/2
    • Insert the 9-volt battery into the cartridge.
    • Press firmly to slide the battery into the cartridge, and close the tab to ensure the battery is secured.
    • Close the tab after the battery is secured, until the tab "clicks" into place.
  4. First Act MA2039 Battery Replacement: 4 단계, 이미지 1/2 First Act MA2039 Battery Replacement: 4 단계, 이미지 2/2
    • Make sure connections are secure and insert 9-volt batteries into the battery cartridges.
    • Close the tabs until you hear a click.
    • Now, try turning on the power switch. Get ready to rock & roll!
결론
Luke VanBuskirk
회원 가입일: 04/05/18
279 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 10
30일 전: 29
전체 시간: 751
