주요 콘텐츠로 건너뛰기
First Act MA2039 Speaker Replacement
필요한 것
  1. First Act MA2039 Speaker Replacement, Speaker: 1 단계, 이미지 1/1
    • Use a Phillips #0 screwdriver to remove the two 25mm screws that secure back panel to amplifier.
  2. First Act MA2039 Speaker Replacement: 2 단계, 이미지 1/2 First Act MA2039 Speaker Replacement: 2 단계, 이미지 2/2
    • Once screws are removed, lift the panel from the amplifier and feed the battery terminals through holes in battery cartridges.
    • Take the panel off and set it to the side.
  3. First Act MA2039 Speaker Replacement: 3 단계, 이미지 1/1
    • Use a Phillips #0 screwdriver to remove the four 25mm screws that fasten the speaker to the inside of the amplifier.
  4. First Act MA2039 Speaker Replacement: 4 단계, 이미지 1/1
    • Desolder the black and white speaker wires from the contact board.
    • The speaker can now be completely removed from the amplifer.
결론
To reassemble your device, use soldering link provided to solder existing wires onto new speaker, then follow these instructions in reverse order.
다른 한 분이 해당 안내서를 완성하였습니다.
Landon Connolly
회원 가입일: 04/05/18
332 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 9
전체 시간: 396
