주요 콘텐츠로 건너뛰기
First Alert Smoke Alarm 9120B Battery Replacement
필요한 것
  1. First Alert Smoke Alarm 9120B Battery Replacement, Battery: 1 단계, 이미지 1/3 First Alert Smoke Alarm 9120B Battery Replacement, Battery: 1 단계, 이미지 2/3 First Alert Smoke Alarm 9120B Battery Replacement, Battery: 1 단계, 이미지 3/3
    • Remove the alarm by rotating it counter clockwise in the mount.
    • The alarm should fall off once rotated enough. The cable should be the only thing holding it in place if done correctly.
  2. First Alert Smoke Alarm 9120B Battery Replacement: 2 단계, 이미지 1/2 First Alert Smoke Alarm 9120B Battery Replacement: 2 단계, 이미지 2/2
    • Unplug the cable from the alarm.
  3. First Alert Smoke Alarm 9120B Battery Replacement: 3 단계, 이미지 1/3 First Alert Smoke Alarm 9120B Battery Replacement: 3 단계, 이미지 2/3 First Alert Smoke Alarm 9120B Battery Replacement: 3 단계, 이미지 3/3
    • Press down on the catch on the top left of the alarm to open the battery compartment.
  4. First Alert Smoke Alarm 9120B Battery Replacement: 4 단계, 이미지 1/2 First Alert Smoke Alarm 9120B Battery Replacement: 4 단계, 이미지 2/2
    • Remove the battery and dispose of it properly.
    • Replace the old battery with a new 9V battery and close the compartment.
    • You should hear a click to know that the compartment is secured.
  5. First Alert Smoke Alarm 9120B Battery Replacement: 5 단계, 이미지 1/2 First Alert Smoke Alarm 9120B Battery Replacement: 5 단계, 이미지 2/2
    • Line up the holes of the cable on the mount with the pins on the alarm.
    • Reconnect the cable on the mount to that on the alarm.
    • It should insert itself with minimal force.
  6. First Alert Smoke Alarm 9120B Battery Replacement: 6 단계, 이미지 1/2 First Alert Smoke Alarm 9120B Battery Replacement: 6 단계, 이미지 2/2
    • Press the alarm into the mount.
  7. First Alert Smoke Alarm 9120B Battery Replacement: 7 단계, 이미지 1/3 First Alert Smoke Alarm 9120B Battery Replacement: 7 단계, 이미지 2/3 First Alert Smoke Alarm 9120B Battery Replacement: 7 단계, 이미지 3/3
    • Rotate the alarm clockwise until it does not turn anymore. This makes sure the alarm is secured.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
Miggy Reyes
회원 가입일: 02/15/21
219 평판
안내서 1개 작성함
Texas Tech, Team S3-G17, Cowan Spring 2021 Texas Tech, Team S3-G17, Cowan Spring 2021 회원
TTU-COWAN-S21S3G17
1 회원
안내서 3개 작성하였습니다
댓글 5개
How do I disconnect the cable? Seems very tight and cannot disconnect.
Jeanne O - 답글
This is related to first alert smoke alarm 9120B. Can not remove connecting cable from alarm. Is very tight. So unable to change battery. Any suggestions?
Jeanne O - 답글
These alarms suck! Pressing the tab and the battery compartment does NOT pop open. I needed a knife to pry it open, and then it had to be forced close. NOT user error! The plastic pins that hold the battery compartment closed don't move out of the way enough to allow opening.
James Durso - 답글
I replaced the battery and it is still beeping, reset the smoke alarm. What should I do now?
Donald Sandford - 답글
Buy and install a new alarm. It’s easier than trying to fix on.
Stephen Taylor - 답글
댓글 쓰기
조회 통계:
24 시간 전: 39
7일 전: 223
30일 전: 1,004
전체 시간: 32,823
