주요 콘텐츠로 건너뛰기
First-gen Honda Odyssey Oil and filter change
필요한 것
  1. First-gen Honda Odyssey Oil and filter change, Oil and Oil filter: 1 단계, 이미지 1/1
    • We'll be changing the oil and filter on my JDM-import 1999 Honda Odyssey with the 2.3L four-cylinder engine
  2. First-gen Honda Odyssey Oil and filter change, Jacking up the vehicle: 2 단계, 이미지 1/2 First-gen Honda Odyssey Oil and filter change, Jacking up the vehicle: 2 단계, 이미지 2/2
    • Thankfully this car has a centre lift point at the front of the subframe at the tow-hook
    • I just used the normal pinch welds to put the jack-stands under
  3. First-gen Honda Odyssey Oil and filter change: 3 단계, 이미지 1/2 First-gen Honda Odyssey Oil and filter change: 3 단계, 이미지 2/2
    • Open up the bonnet/hood for more light under the vehicle
    • I like to use cardboard to climb under the car
  4. First-gen Honda Odyssey Oil and filter change, Drain the oil pan: 4 단계, 이미지 1/3 First-gen Honda Odyssey Oil and filter change, Drain the oil pan: 4 단계, 이미지 2/3 First-gen Honda Odyssey Oil and filter change, Drain the oil pan: 4 단계, 이미지 3/3
    • Position your drain pan, the drain bolt faces towards the rear of the oilpan
    • On this 1999 Odyssey it was a 23mm drain bolt
  5. First-gen Honda Odyssey Oil and filter change, Remove old oil filter: 5 단계, 이미지 1/3 First-gen Honda Odyssey Oil and filter change, Remove old oil filter: 5 단계, 이미지 2/3 First-gen Honda Odyssey Oil and filter change, Remove old oil filter: 5 단계, 이미지 3/3
    • One of the hardest parts of this procedure
    • Honda put the oil filter mounting on the back of the engine block under the intake manifold
    • You have to reach past the subframe, exhaust, and axle
    • I like to use oil-filter pliers, but there are a few different tools that can be used
    • Check to make sure the gasket came off with the old filter and did not get left behind on the block
  6. First-gen Honda Odyssey Oil and filter change, Install a new oil filter: 6 단계, 이미지 1/3 First-gen Honda Odyssey Oil and filter change, Install a new oil filter: 6 단계, 이미지 2/3 First-gen Honda Odyssey Oil and filter change, Install a new oil filter: 6 단계, 이미지 3/3
    • I used a JS Asakashi C-307J, (made in Japan)
    • I can order them shipped from Singapore cheaper then I can buy locally from Repco or Supercheap here in New Zealand
    • Oil up the gasket on the new filter
    • Clean the mounting plate on the block with your rags
  7. First-gen Honda Odyssey Oil and filter change, Check your work: 7 단계, 이미지 1/1
    • If you've not already, put the drain bolt back in
    • Tighten the new oil filter 3/4 of a turn after it touches the block
    • Tighten the drain bolt without breaking it off :)
    • Clean around the filter and bolt with a rag so you can see any leaks
  8. First-gen Honda Odyssey Oil and filter change, Lower the car: 8 단계, 이미지 1/2 First-gen Honda Odyssey Oil and filter change, Lower the car: 8 단계, 이미지 2/2
    • Remove your cardboard and tools
    • Lift the car again from the centre lift point with your hydraulic jack
    • Pull the jack-stands out from each side
    • Carefully lower the car to the ground, leveling it for filling
  9. First-gen Honda Odyssey Oil and filter change, Fill the car: 9 단계, 이미지 1/1
    • In the photo, the red circle is the oil fill point, and the yellow circle is the dipstick
    • I used Nulon 10W-40 full synthetic
    • I needed about 4.5L or so to fill
    • I like to use a stubby wide-mouth funnel
    • Pour large oil bottles sideways to reduce the blub-blub effect
  10. First-gen Honda Odyssey Oil and filter change, Check for leaks and re-check level: 10 단계, 이미지 1/2 First-gen Honda Odyssey Oil and filter change, Check for leaks and re-check level: 10 단계, 이미지 2/2
    • Run the engine for about 10 seconds to fill up the filter and oil galleys
    • Turn the engine off and check for leaks
    • Check the level using the dipstick and a rag again, it should have gone down a bit due to the oil filter filling up
    • Top up the level to the upper range of the dipstick
결론
Servicing done!
다른 한 분이 해당 안내서를 완성하였습니다.
Gaspard Leon
회원 가입일: 04/24/10
2,831 평판
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 40
전체 시간: 3,619
