주요 콘텐츠로 건너뛰기
Fitbit Alta Wristband Replacement
  1. Fitbit Alta Wristband Replacement, Wristband: 1 단계, 이미지 1/1
    • To release a latch, press down on the flat metal button holding the band to the Fitbit Alta. Pull up on the latch to release the band from the body.
  2. Fitbit Alta Wristband Replacement: 2 단계, 이미지 1/1
    • Slide the band up to release it from the Fitbit Alta tracker. Then, repeat on the other side to remove the band.
  3. Fitbit Alta Wristband Replacement: 3 단계, 이미지 1/3 Fitbit Alta Wristband Replacement: 3 단계, 이미지 2/3 Fitbit Alta Wristband Replacement: 3 단계, 이미지 3/3
    • Turn over the Fitbit Alta so the bands are facing upward.
    • Press the latches inward and remove each band by lifting upward.
결론
To reassemble your device, follow these instructions in reverse order. When you hear a click , the wristband is secure.
다른 13명이 해당 안내서를 완성하였습니다.
Zach Gorham
회원 가입일: 02/28/17
398 평판
안내서 1개 작성함
University of Memphis, Team S4-G3, Baddour Spring 2017 University of Memphis, Team S4-G3, Baddour Spring 2017 회원
UM-BADDOUR-S17S4G3
2 회원들
안내서 2개 작성하였습니다
댓글 2개
Excellent! Thanks so much!
JUDITH DIGENOVA - 답글
My band broke off and the tab used for removal broke and I cannot get my remnant of my band off. What are the steps for removing the band if the tab is broken?
godz.gal.52 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 39
전체 시간: 11,806
