소개
This is a quick and easy guide to replace the wristband of a Fitbit Alta. No tools are required in the process.
To release a latch, press down on the flat metal button holding the band to the Fitbit Alta. Pull up on the latch to release the band from the body.
To reassemble your device, follow these instructions in reverse order. When you hear a click , the wristband is secure.
다른 13명이 해당 안내서를 완성하였습니다.
댓글 2개
Excellent! Thanks so much!
My band broke off and the tab used for removal broke and I cannot get my remnant of my band off. What are the steps for removing the band if the tab is broken?
