주요 콘텐츠로 건너뛰기
Fitbit Charge 2 Touch Screen Assembly Replacement
필요한 것
  1. Fitbit Charge 2 Touch Screen Assembly Replacement, Remove the watch band: 1 단계, 이미지 1개 중 1개
    • Before starting, take your Fitbit Charge 2 off the charger and power it down.
    • Remove the watch band on both sides.
  2. Fitbit Charge 2 Touch Screen Assembly Replacement, Heat the touch screen: 2 단계, 이미지 1개 중 1개
    • Heat an iOpener and apply it to the touch screen for two minutes.
    • The screen is not glued down, but the heat helps to loosen the touch screen assembly from your watch.
  3. Fitbit Charge 2 Touch Screen Assembly Replacement, Slide along the left edge: 3 단계, 이미지 3개 중 1개 Fitbit Charge 2 Touch Screen Assembly Replacement, Slide along the left edge: 3 단계, 이미지 3개 중 2개 Fitbit Charge 2 Touch Screen Assembly Replacement, Slide along the left edge: 3 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    iSesamo Opening Tool
    $9.99
    • Insert an iSesamo into the gap between the touch screen and the watch assembly on the top left corner.
    • Slide the iSesamo along the left edge to the bottom left corner.
  4. Fitbit Charge 2 Touch Screen Assembly Replacement, Slide along the bottom edge: 4 단계, 이미지 2개 중 1개 Fitbit Charge 2 Touch Screen Assembly Replacement, Slide along the bottom edge: 4 단계, 이미지 2개 중 2개
    • Slide the iSesamo around the bottom left corner.
    • Slide it along the edge to the bottom right corner.
  5. Fitbit Charge 2 Touch Screen Assembly Replacement: 5 단계, 이미지 3개 중 1개 Fitbit Charge 2 Touch Screen Assembly Replacement: 5 단계, 이미지 3개 중 2개 Fitbit Charge 2 Touch Screen Assembly Replacement: 5 단계, 이미지 3개 중 3개
    • Slide the iSesamo around the bottom right corner.
    • Keep sliding it along the right edge to the top right corner.
  6. Fitbit Charge 2 Touch Screen Assembly Replacement: 6 단계, 이미지 2개 중 1개 Fitbit Charge 2 Touch Screen Assembly Replacement: 6 단계, 이미지 2개 중 2개
    • Slide the iSesamo around the top right corner.
    • Slide it along the top edge to the top left corner.
  7. Fitbit Charge 2 Touch Screen Assembly Replacement: 7 단계, 이미지 2개 중 1개 Fitbit Charge 2 Touch Screen Assembly Replacement: 7 단계, 이미지 2개 중 2개
    • Place the iSesamo under the top left corner.
    • Feel free to reattach the watch band for this and the next step for a better grip.
    • Pry up the touch screen assembly by twisting the iSesamo sideways to create a gap and unhinge the plastic clips which are holding the screen in place.
  8. Fitbit Charge 2 Touch Screen Assembly Replacement: 8 단계, 이미지 2개 중 1개 Fitbit Charge 2 Touch Screen Assembly Replacement: 8 단계, 이미지 2개 중 2개
    • Place the iSesamo under the top right corner.
    • Pry up the touch screen assembly by twisting the iSesamo sideways to create a gap.
  9. Fitbit Charge 2 Touch Screen Assembly Replacement: 9 단계, 이미지 2개 중 1개 Fitbit Charge 2 Touch Screen Assembly Replacement: 9 단계, 이미지 2개 중 2개
    • Insert a spudger into the gap on the top edge of your Fitbit Charge 2.
    • Use the spudger to pry up the touch screen assembly.
    • Do not remove the touch screen assembly all the way yet—it's still connected to the motherboard.
  10. Fitbit Charge 2 Touch Screen Assembly Replacement: 10 단계, 이미지 1개 중 1개
    • Carefully fold the touch screen assembly in the direction of the bottom edge.
  11. Fitbit Charge 2 Touch Screen Assembly Replacement, Remove the protecting sticker: 11 단계, 이미지 2개 중 1개 Fitbit Charge 2 Touch Screen Assembly Replacement, Remove the protecting sticker: 11 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use a pair of blunt nosed tweezers to remove the black sticker which covering the touch screen connector.
  12. Fitbit Charge 2 Touch Screen Assembly Replacement, Open the ZIF connector: 12 단계, 이미지 2개 중 1개 Fitbit Charge 2 Touch Screen Assembly Replacement, Open the ZIF connector: 12 단계, 이미지 2개 중 2개
    • Use the pointed end of a spudger to open the ZIF connector by pushing up the black flap.
  13. Fitbit Charge 2 Touch Screen Assembly Replacement, Remove the touch screen assembly: 13 단계, 이미지 3개 중 1개 Fitbit Charge 2 Touch Screen Assembly Replacement, Remove the touch screen assembly: 13 단계, 이미지 3개 중 2개 Fitbit Charge 2 Touch Screen Assembly Replacement, Remove the touch screen assembly: 13 단계, 이미지 3개 중 3개
    • Pull the touch screen flex cable straight out its socket.
    • Remove the touch screen assembly.
결론
If possible, turn on your device and test your repair before reassemble.
Opening didn’t go as planned? Ask our Answers community for help.
다른 12명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Adriana Zwink
회원 가입일: 12/18/19
61,760 평판
안내서 167개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,608개를 작성함
1가이드 댓글
This is great
Mohsen - 답글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 19
지난 30일: 90
전체 시간: 16,553
