주요 콘텐츠로 건너뛰기
Fitbit Charge HR Vibration Motor Replacement
필요한 것
  1. Fitbit Charge HR Vibration Motor Replacement, Vibration Motor: 1 단계, 이미지 1/1
    • Remove the four 2.9 mm screws from the back of the display using a Torx screwdriver.
    • Remove the back cover from the device.
  2. Fitbit Charge HR Vibration Motor Replacement: 2 단계, 이미지 1/3 Fitbit Charge HR Vibration Motor Replacement: 2 단계, 이미지 2/3 Fitbit Charge HR Vibration Motor Replacement: 2 단계, 이미지 3/3
    • Remove the two 2.9 mm Torx screws holding the circuit board in place.
    • Carefully pry the board out using an opening tool.
  3. Fitbit Charge HR Vibration Motor Replacement: 3 단계, 이미지 1/1
    • Remove the motherboard assembly from the device by gently lifting.
  4. Fitbit Charge HR Vibration Motor Replacement: 4 단계, 이미지 1/2 Fitbit Charge HR Vibration Motor Replacement: 4 단계, 이미지 2/2
    • Locate the vibration motor on the motherboard.
    • Desolder the red and black wires connected to the motherboard from the vibration motor.
    • Red wire is located closer to the outside. Black wire is closer to the inside of the motherboard.
    • Replace with new vibration motor.
결론
Aekchanin Iamborisut
회원 가입일: 09/20/21
259 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 15
전체 시간: 410
