주요 콘텐츠로 건너뛰기
Fitbit Charge HR Vibration Motor Replacement
필요한 것
  1. Fitbit Charge HR Vibration Motor Replacement, Vibration Motor: 1 단계, 이미지 1개 중 1개
    • Remove the four 2.9 mm screws from the back of the display using a Torx screwdriver.
    • Remove the back cover from the device.
  2. Fitbit Charge HR Vibration Motor Replacement: 2 단계, 이미지 3개 중 1개 Fitbit Charge HR Vibration Motor Replacement: 2 단계, 이미지 3개 중 2개 Fitbit Charge HR Vibration Motor Replacement: 2 단계, 이미지 3개 중 3개
    • Remove the two 2.9 mm Torx screws holding the circuit board in place.
    • Carefully pry the board out using an opening tool.
  3. Fitbit Charge HR Vibration Motor Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the motherboard assembly from the device by gently lifting.
  4. Fitbit Charge HR Vibration Motor Replacement: 4 단계, 이미지 2개 중 1개 Fitbit Charge HR Vibration Motor Replacement: 4 단계, 이미지 2개 중 2개
    • Locate the vibration motor on the motherboard.
    • Desolder the red and black wires connected to the motherboard from the vibration motor.
    • Red wire is located closer to the outside. Black wire is closer to the inside of the motherboard.
    • Replace with new vibration motor.
결론
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 11
전체 시간: 601
