주요 콘텐츠로 건너뛰기
Fitbit FB502SBUL Wristband Replacement
필요한 것
  1. Fitbit FB502SBUL Wristband Replacement, Wristband: 1 단계, 이미지 1/2 Fitbit FB502SBUL Wristband Replacement, Wristband: 1 단계, 이미지 2/2
    • Locate the front LCD screen on your device.
    • Fitbit logo should appear in the bottom center of the screen.
  2. Fitbit FB502SBUL Wristband Replacement: 2 단계, 이미지 1/1
    • Push the screen out through the back of the metal ring enclosure.
    • Use a small amount of force on screen to prevent damage. Use other hand to catch screen.
  3. Fitbit FB502SBUL Wristband Replacement: 3 단계, 이미지 1/3 Fitbit FB502SBUL Wristband Replacement: 3 단계, 이미지 2/3 Fitbit FB502SBUL Wristband Replacement: 3 단계, 이미지 3/3
    • Locate the metal pin behind the wristband located on the edge of metal ring.
    • Insert the pointed end of the metal spudger into the pin hold and push it into the blue rectangle enclosure.
    • Use a small amount of force to avoid damaging the pins.
    • Remove wristband.
결론
Adrian Borrego
회원 가입일: 02/20/17
2,242 평판
안내서 5개 작성하였습니다
USF Tampa, Team S3-G3, Sullivan Spring 2017 USF Tampa, Team S3-G3, Sullivan Spring 2017 회원
USFT-SULLIVAN-S17S3G3
4 회원들
안내서 15개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 11
전체 시간: 1,456
