주요 콘텐츠로 건너뛰기
Fitbit Inspire 2 Wrist Straps Replacement
필요한 것
  1. Fitbit Inspire 2 Wrist Straps Replacement, Wrist Straps: 1 단계, 이미지 3개 중 1개 Fitbit Inspire 2 Wrist Straps Replacement, Wrist Straps: 1 단계, 이미지 3개 중 2개 Fitbit Inspire 2 Wrist Straps Replacement, Wrist Straps: 1 단계, 이미지 3개 중 3개
    • Use a spudger or your fingernail to push back the release lever on one of the two straps on the underside of the Fitbit.
    • You may experience some resistance from the release, but don't use excessive force, as it may damage the release levers.
  2. Fitbit Inspire 2 Wrist Straps Replacement: 2 단계, 이미지 3개 중 1개 Fitbit Inspire 2 Wrist Straps Replacement: 2 단계, 이미지 3개 중 2개 Fitbit Inspire 2 Wrist Straps Replacement: 2 단계, 이미지 3개 중 3개
    • As you pull back the release lever, shift the strap diagonally.
    • Remove from the Fitbit strap.
    • Repeat the process for the other strap.
  3. Fitbit Inspire 2 Wrist Straps Replacement: 3 단계, 이미지 2개 중 1개 Fitbit Inspire 2 Wrist Straps Replacement: 3 단계, 이미지 2개 중 2개
    • Now that the old straps are detached from the Fitbit, take the opportunity to clean the watch and strap connection points.
    • Use a spudger to clean the inside of the strap chamber. Scrape out any residue or grime that may have built up over the past months or years.
  4. Fitbit Inspire 2 Wrist Straps Replacement: 4 단계, 이미지 1개 중 1개
    • Slide the replacement straps into the given slot and the lever will click back into place.
  5. Fitbit Inspire 2 Wrist Straps Replacement: 5 단계, 이미지 2개 중 1개 Fitbit Inspire 2 Wrist Straps Replacement: 5 단계, 이미지 2개 중 2개
    • The straps should be secure and you can wear your watch again!
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
MarcSerpa
회원 가입일: 01/09/24
142 평판
안내서 1개를 작성함
York University, Team 2-2, O'Regan Winter 2024 York University, Team 2-2, O'Regan Winter 2024 회원
YORK-O'REGAN-W24S2G2
1 회원
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 29
전체 시간: 582
