주요 콘텐츠로 건너뛰기
Fitbit Luxe screen assembly Replacement
  1. Fitbit Luxe screen assembly Replacement, pry out screen: 1 단계, 이미지 1개 중 1개
    • the screen is glued down with a silicone flexible type glue on a 1mm or less edge, that you need to loosen with a hot air soldering blower. make sure the temperature does not get too high that you burn or melt the plastic clips that connect the bands.
    • I expect to replace the screen again if I ever need to replace the battery, because it will probably crack as i try to pry it out
    • This Fitbit had a very cracked screen, which was extremely handy for finding leverage to take out the screen.
  2. Fitbit Luxe screen assembly Replacement, fold out screen: 2 단계, 이미지 1개 중 1개
    • screen assembly folds out to the side attached by 1 ribbon cable
    • the longer vertical clip holds the ribbon cable down
  3. Fitbit Luxe screen assembly Replacement, take out screw for retainer clip: 3 단계, 이미지 1개 중 1개
    • flip out battery, the battery ribbon cable is on the left top side (top side is where you can see the conctacts)
    • there is a very small T2 torx screw under there.
    • remove this screw and the clip holding down part of the screen ribbon comes out. It also releases the larger shield under the battery
  4. Fitbit Luxe screen assembly Replacement, retainer clip is out: 4 단계, 이미지 1개 중 1개
    • the long part of that clip hooks under a little tab in the fitbit frame.
  5. Fitbit Luxe screen assembly Replacement, take out shield under battery: 5 단계, 이미지 1개 중 1개
    • mind, this shield hooks under something at the bottom part.
  6. Fitbit Luxe screen assembly Replacement, move battery out of the way: 6 단계, 이미지 1개 중 1개
    • carfully move over battery
  7. Fitbit Luxe screen assembly Replacement, unplug screen: 7 단계, 이미지 1개 중 1개
    • unplug the screen assembly cable.
    • if you reinstall, make sure that little sponge doesn't get stuck between the connector and port
  8. Fitbit Luxe screen assembly Replacement, reinstall screen and retrace steps: 8 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • for reassembly: the part indicated, of the shield that goes under the battery, needs to be inserted under an angle: it hooks under something indicated in the image by the tweezers.
  9. Fitbit Luxe screen assembly Replacement, finished.: 9 단계, 이미지 1개 중 1개
    • this works again.
    • for getting the screw in, I needed to hot-glue the little screw onto the screwdriver, because many (internal) parts of the fitbit are magnetic, so its very difficult to not lose the little screw that holds the shield and clip in place.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Hans Bruch jr
회원 가입일: 02/27/11
937 평판
안내서 3개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 10
지난 30일: 95
전체 시간: 2,546
