주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Fitbit Surge Battery Replacement
필요한 것
  1. Fitbit Surge Battery Replacement, Battery: 1 단계, 이미지 2개 중 1개 Fitbit Surge Battery Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Unscrew all four black 3 mm Phillips screws on the underside of the watch using a T5 screwdriver.
  2. Fitbit Surge Battery Replacement: 2 단계, 이미지 3개 중 1개 Fitbit Surge Battery Replacement: 2 단계, 이미지 3개 중 2개 Fitbit Surge Battery Replacement: 2 단계, 이미지 3개 중 3개
    • Use an X-Acto knife to cut the band above, on either side, and in between the 2 screws.
    • Note: Part of the band is hard plastic.
    • Caution: The band cannot be reattached once it is cut.
  3. Fitbit Surge Battery Replacement: 3 단계, 이미지 2개 중 1개 Fitbit Surge Battery Replacement: 3 단계, 이미지 2개 중 2개
    • Scrape away the glue beneath the hard shell portion of the band to reveal the GPS.
  4. Fitbit Surge Battery Replacement: 4 단계, 이미지 2개 중 1개 Fitbit Surge Battery Replacement: 4 단계, 이미지 2개 중 2개
    • Use a PH000 screw head to undo the newly revealed silver 4 mm Phillips screws that were hidden beneath the glue.
  5. Fitbit Surge Battery Replacement: 5 단계, 이미지 2개 중 1개 Fitbit Surge Battery Replacement: 5 단계, 이미지 2개 중 2개
    • Using a metal spudger, push down on the plastic gray square clamps on the underside of the device to dislodge the whole silver backing.
    • Note: the buttons will also come off.
  6. Fitbit Surge Battery Replacement: 6 단계, 이미지 1개 중 1개
    • Use a pick or small flathead to remove the 4 metal clamps holding device together.
    • Use a thin tool to pry the the device apart by lodging it between the clock face and back side of the device.
    • Note: a spudger may not be thin enough to fit in the seam of the device. We used the 6 inch metal ruler from the Pro Tech Toolkit.
    • Go slowly and carefully disconnect two cables before fully opening.
  7. Fitbit Surge Battery Replacement: 7 단계, 이미지 1개 중 1개
    • Gently remove the battery.
결론
To reassemble your device, follow these instructions in reverse order. Keep in mind that the band will need to be cut for this repair and it cannot be reattached.
다른 11명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Angela Pitts
회원 가입일: 10/11/16
1,190 평판
안내서 4개를 작성함
USF Tampa, Team 1-3, Leahy Fall 2016 USF Tampa, Team 1-3, Leahy Fall 2016 회원
USFT-LEAHY-F16S1G3
3 회원들
안내서 4개를 작성함
10가이드 댓글
I'm about to embark on replacing the battery for my fitbit surge. After having it for over 2 years it requires a charge about twice a day which get annoying.
Does removing/replacing the battery require the moderate soldering skill?
L “Rico” Hirano - 답글
Looks like it must.
Chaspsmith - 답글
The last photo I think shows the tool prying the force feedback motor, the battery is the white plastic covered slim brick on the top right.
csaba.toth.us - 답글
You do not need to cut bands off
Tim master - 답글
The replacement battery for the Fitbit Surge can be found here:
It also includes all of the tools (except soldering iron) needed for the repair.
michaelf33707 - 답글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 25
지난 30일: 103
전체 시간: 20,501
