주요 콘텐츠로 건너뛰기
Fitbit Surge GPS Replacement
필요한 것
  1. Fitbit Surge GPS Replacement, Fitbit Surge GPS Replacement: 1 단계, 이미지 1/2 Fitbit Surge GPS Replacement, Fitbit Surge GPS Replacement: 1 단계, 이미지 2/2
    • Unscrew all four black 3 mm Phillips screws on the underside of the watch using a T5 screwdriver.
  2. Fitbit Surge GPS Replacement: 2 단계, 이미지 1/3 Fitbit Surge GPS Replacement: 2 단계, 이미지 2/3 Fitbit Surge GPS Replacement: 2 단계, 이미지 3/3
    • Use an X-Acto knife to cut the band above, on either side, and in between the 2 screws.
    • Note: Part of the band is hard plastic.
    • Caution: Once the band is cut it cannot be reattached.
  3. Fitbit Surge GPS Replacement: 3 단계, 이미지 1/2 Fitbit Surge GPS Replacement: 3 단계, 이미지 2/2
    • Scrape away the glue beneath the hard shell portion of the band to reveal the GPS.
  4. Fitbit Surge GPS Replacement: 4 단계, 이미지 1/2 Fitbit Surge GPS Replacement: 4 단계, 이미지 2/2
    • Use a PH000 screw head to undo the newly revealed 4 mm Phillips screws that were hidden beneath the glue.
결론
To reassemble your device, follow these instructions in reverse order. Keep in mind that you will need to cut the band for this guide and it cannot be reattached.
다른 3명이 해당 안내서를 완성하였습니다.
Angela Pitts
회원 가입일: 10/11/16
1,187 평판
안내서 4개 작성하였습니다
USF Tampa, Team 1-3, Leahy Fall 2016 USF Tampa, Team 1-3, Leahy Fall 2016 회원
USFT-LEAHY-F16S1G3
3 회원들
안내서 4개 작성하였습니다
댓글 한 개
Where do you get the parts to replace the GPS or the screen ?
Christine Arends - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 2,940
