주요 콘텐츠로 건너뛰기
Fitted Bed Sheet Elastic Replacement
필요한 것
  1. Fitted Bed Sheet Elastic Replacement, Elastic: 1 단계, 이미지 3개 중 1개 Fitted Bed Sheet Elastic Replacement, Elastic: 1 단계, 이미지 3개 중 2개 Fitted Bed Sheet Elastic Replacement, Elastic: 1 단계, 이미지 3개 중 3개
    • Make a small cut in elastic casing at the edge of the fabric seam to access the elastic inside.
    • With your sewing scissors, carefully cut the stitches that attach the elastic to the fabric, if sewn in place.
    • On some sheets, the elastic isn’t sewn directly to the fabric—it’s threaded through a casing and can be pulled out.
    • Gently pull the elastic to detach it from the fabric.
    • Continue cutting and pulling the elastic until it completely detaches from the casing.
  2. Fitted Bed Sheet Elastic Replacement: 2 단계, 이미지 2개 중 1개 Fitted Bed Sheet Elastic Replacement: 2 단계, 이미지 2개 중 2개
    • Use a measuring tape, to measure the length of the old elastic.
    • Keep the elastic as flat and straight as possible to get an accurate measure. This will help you determine the length of the new elastic.
  3. Fitted Bed Sheet Elastic Replacement: 3 단계, 이미지 2개 중 1개 Fitted Bed Sheet Elastic Replacement: 3 단계, 이미지 2개 중 2개
    • Lay the new elastic flat on a table. Use the old elastic as a reference, measure the same length with a measuring tape, and mark it with tailor's chalk.
    • If your old elastic was overly damaged, shorten the length by 1-2 inches to ensure tightness.
    • With sewing scissors, cut the new elastic at the marked length.
    • If you are unsure of the length, you can start with a longer piece and trim the excess afterwards.
  4. Fitted Bed Sheet Elastic Replacement: 4 단계, 이미지 2개 중 1개 Fitted Bed Sheet Elastic Replacement: 4 단계, 이미지 2개 중 2개
    • Overlap the ends of the new elastic.
    • If you need, pin them to keep them secure.
    • With your sewing machine, sew the ends securely using a straight stitch to ensure strength under tension.
    • Ensure the elastic lies flat and isn't twisted before sewing.
  5. Fitted Bed Sheet Elastic Replacement: 5 단계, 이미지 3개 중 1개 Fitted Bed Sheet Elastic Replacement: 5 단계, 이미지 3개 중 2개 Fitted Bed Sheet Elastic Replacement: 5 단계, 이미지 3개 중 3개
    • Align the elastic along the edge of the sheet, about 1/2 inch from the edge.
    • Use pins to keep it in place.
    • Secure the elastic with an anchor stitch by sewing back and forth a few times to hold it in place and prevent the elastic from shifting as you sew.
    • Start folding the fabric over the elastic to create a casing. Fold the fabric far enough to cover the elastic.
    • Sew along the folded edge with a straight stitch, gently stretching the elastic as you go.
    • Keep your elastic centered inside the fold.
    • Work in small sections as you fold, stretch, and sew.
  6. Fitted Bed Sheet Elastic Replacement: 6 단계, 이미지 2개 중 1개 Fitted Bed Sheet Elastic Replacement: 6 단계, 이미지 2개 중 2개
    • When you've sewn the elastic all the way around, make a small stitch by sewing back and forth where the ends meet.
    • Give the sheet a stretch to ensure the elastic can move freely and gather the fabric evenly.
    • Inspect the entire seam to ensure it's holding the elastic securely. If you see any skipped stitches or loose spots, reinforce them with a few extra passes with your sewing machine.
결론
작성자
1다른 기여자 명과 함께
Jen43
회원 가입일: 04/09/25
133 평판
안내서 1개를 작성함
CSU Los Angeles, Team 5-43, Harris Spring 2025 CSU Los Angeles, Team 5-43, Harris Spring 2025 회원
CSULA-HARRIS-S25S5G43
1 회원
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 6
지난 7일: 29
지난 30일: 198
전체 시간: 874
