주요 콘텐츠로 건너뛰기
Fitting Ski Bindings to a New Pair of Boots
필요한 것
  1. Fitting Ski Bindings to a New Pair of Boots, Fitting Ski Bindings to a New Pair of Boots: 1 단계, 이미지 1/1
    • Locate the boot size (in millimeters) on the bottom of the boot.
    • If the boot size is not on the bottom, check the inner or outer sides of the heel.
    • In our case, the size is 316mm. However, this may not be the case for everyone.
  2. Fitting Ski Bindings to a New Pair of Boots: 2 단계, 이미지 1/3 Fitting Ski Bindings to a New Pair of Boots: 2 단계, 이미지 2/3 Fitting Ski Bindings to a New Pair of Boots: 2 단계, 이미지 3/3
    • Place your ski on a flat surface with the ski bindings facing up.
    • Locate the lever on the side of the heel piece of the binding.
    • Lift and hold the lever in the upright position.
  3. Fitting Ski Bindings to a New Pair of Boots: 3 단계, 이미지 1/3 Fitting Ski Bindings to a New Pair of Boots: 3 단계, 이미지 2/3 Fitting Ski Bindings to a New Pair of Boots: 3 단계, 이미지 3/3
    • With the lever raised, slide the heel piece until the markers point to the correct range of the boot size.
    • Given the boot size in this guide is 316mm, the correct range for this ski boot is 311mm - 318mm. This may not be the case for everyone.
  4. Fitting Ski Bindings to a New Pair of Boots: 4 단계, 이미지 1/3 Fitting Ski Bindings to a New Pair of Boots: 4 단계, 이미지 2/3 Fitting Ski Bindings to a New Pair of Boots: 4 단계, 이미지 3/3
    • Locate the lever on the toe piece of the binding.
  5. Fitting Ski Bindings to a New Pair of Boots: 5 단계, 이미지 1/3 Fitting Ski Bindings to a New Pair of Boots: 5 단계, 이미지 2/3 Fitting Ski Bindings to a New Pair of Boots: 5 단계, 이미지 3/3
    • With the lever raised, slide the toe piece until the markers point to the correct boot size range.
    • Given the boot size in this guide is 316mm, the correct range for this ski boot is 315mm - 322mm. This may not be the case for everyone.
  6. Fitting Ski Bindings to a New Pair of Boots: 6 단계, 이미지 1/3 Fitting Ski Bindings to a New Pair of Boots: 6 단계, 이미지 2/3 Fitting Ski Bindings to a New Pair of Boots: 6 단계, 이미지 3/3
    • Insert the toe of the boot into the toe piece of the binding.
    • Push down on the boot until the boot clips into the binding. If needed, you can lift the lever on the heel piece to facilitate the procedure.
  7. Fitting Ski Bindings to a New Pair of Boots: 7 단계, 이미지 1/2 Fitting Ski Bindings to a New Pair of Boots: 7 단계, 이미지 2/2
    • Insert the screwdriver in the front of the toe piece.
    • Loosen the screw until the toe bar moves backwards.
    • You should be able to fit a piece of paper between the bottom of the boot and the toe bar.
  8. Fitting Ski Bindings to a New Pair of Boots: 8 단계, 이미지 1/2 Fitting Ski Bindings to a New Pair of Boots: 8 단계, 이미지 2/2
    • Insert a piece of paper between the bottom of the boot and the toe bar.
    • Tighten the screw at the front of the toe piece until there is resistance when pulling the paper out.
    • You should be able to pull the paper out without it ripping but not push it back in.
    • Over-tightening of the toe bar can be dangerous. Practice caution and take your time.
  9. Fitting Ski Bindings to a New Pair of Boots: 9 단계, 이미지 1/2 Fitting Ski Bindings to a New Pair of Boots: 9 단계, 이미지 2/2
    • Adjust the DIN setting on the toe piece to your personalized setting by tightening or loosening the screw on the side of the bindings.
    • Look at the window on the top of the toe piece to see the current DIN setting.
    • Skiing with a DIN setting that is too high can be dangerous, because the bidding won't be activated if the ski is subject to high strains. Use caution to not over-tighten the screw. On the contrary, a low value will cause undesired activations of the binding, which can be dangerous, too.
  10. Fitting Ski Bindings to a New Pair of Boots: 10 단계, 이미지 1/3 Fitting Ski Bindings to a New Pair of Boots: 10 단계, 이미지 2/3 Fitting Ski Bindings to a New Pair of Boots: 10 단계, 이미지 3/3
    • Repeat step 9 but on the heel piece.
    • Adjust the DIN setting on the heel piece by tightening or loosening the screw on the back.
    • Look at the window on the top of the heel piece to see the current DIN setting.
    • Skiing with a DIN setting that is too high can be dangerous. Use caution to not over-tighten the screw.
결론
Repeat this guide on the other ski and you’re ready to go!
다른 3명이 해당 안내서를 완성하였습니다.
Veronica Contreras
회원 가입일: 02/20/20
217 평판
안내서 1개 작성함
UC Davis, Team S1-G3, Andersen Winter 2020 UC Davis, Team S1-G3, Andersen Winter 2020 회원
UCD-ANDERSEN-W20S1G3
4 회원들
안내서 5개 작성하였습니다
댓글 4개
Super Anleitung, vielen Dank. Das erspart mir eine Fahrt quer durch die Stadt zum Sportgeschäft!
Joerg Schnur - 답글
Joerg Schnur - 답글
Kürzer und klarer geht es nicht. Alle horizontalen und vertikalen Fragen sind beantwortet. Danke
Andreas Rothe - 답글
Sehr gute Anleitung auch für Anfänger.
Tuzzer 2 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 28
30일 전: 155
전체 시간: 70,273
