주요 콘텐츠로 건너뛰기
Fix LG G3 "SIM Card Removed" or "Service Disabled" issue
필요한 것
  1. Fix LG G3 "SIM Card Removed" or "Service Disabled" issue, Fix LG G3 "SIM Card Removed" or "Service Disabled" issue: 1 단계, 이미지 1/3 Fix LG G3 "SIM Card Removed" or "Service Disabled" issue, Fix LG G3 "SIM Card Removed" or "Service Disabled" issue: 1 단계, 이미지 2/3 Fix LG G3 "SIM Card Removed" or "Service Disabled" issue, Fix LG G3 "SIM Card Removed" or "Service Disabled" issue: 1 단계, 이미지 3/3
    • My LG G3 had "Service Disabled" and "SIM Card Removed" come up more and more.
    • First power off, remove the back cover and place the screen on a stable surface.
    • Use J0 or similar Phillips driver, REALLY tighten all 13 screws, using downward pressure to keep the drive in place. But be careful not to damage any part.
    • Then put the battery, the SIM and the back cover back, and power on. Good luck!
결론
다른 9명이 해당 안내서를 완성하였습니다.
Matthew Keating
회원 가입일: 12/21/15
321 평판
안내서 1개 작성함
댓글 4개
i did solved with hard reset
Paresh Das - 답글
i did solved with a hard reset
Paresh Das - 답글
Did as mentioned and so far 3 days later no rebooting of phone with messages saying invalid sim card…. Here’s hoping it continues… thank you so much! Dale
asialink - 답글
Tried this fix and noticed that the screw nearest to the main camera lens was loose. Tightened it and all the others screws as recommended, and the issue was resolved.
Chris Poole - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 31
전체 시간: 17,227
