주요 콘텐츠로 건너뛰기
Fix a Loose Mounting Dream MD2462 TV Wall Mount
필요한 것
  1. Fix a Loose Mounting Dream MD2462 TV Wall Mount, Fix a Loose Mounting Dream MD2462 TV Wall Mount: 1 단계, 이미지 1/3 Fix a Loose Mounting Dream MD2462 TV Wall Mount, Fix a Loose Mounting Dream MD2462 TV Wall Mount: 1 단계, 이미지 2/3 Fix a Loose Mounting Dream MD2462 TV Wall Mount, Fix a Loose Mounting Dream MD2462 TV Wall Mount: 1 단계, 이미지 3/3
    • Remove the two M4x5mm bolts on the back of the TV plate using a Phillips #00 screwdriver.
    • Unplug the TV cables before removing the TV from the wall.
  2. Fix a Loose Mounting Dream MD2462 TV Wall Mount: 2 단계, 이미지 1/3 Fix a Loose Mounting Dream MD2462 TV Wall Mount: 2 단계, 이미지 2/3 Fix a Loose Mounting Dream MD2462 TV Wall Mount: 2 단계, 이미지 3/3
    • Remove the three lag bolts from the wall mount by using a 13mm open-end wrench.
    • If it is too loose, it can just be pulled out.
  3. Fix a Loose Mounting Dream MD2462 TV Wall Mount: 3 단계, 이미지 1/3 Fix a Loose Mounting Dream MD2462 TV Wall Mount: 3 단계, 이미지 2/3 Fix a Loose Mounting Dream MD2462 TV Wall Mount: 3 단계, 이미지 3/3
    • Fill the holes where the screws were secured using drywall spackle.
  4. Fix a Loose Mounting Dream MD2462 TV Wall Mount: 4 단계, 이미지 1/1
    • Locate the wooden studs on the wall using a stud finder or knock on the wall to see if the stud is behind the wall.
  5. Fix a Loose Mounting Dream MD2462 TV Wall Mount: 5 단계, 이미지 1/3 Fix a Loose Mounting Dream MD2462 TV Wall Mount: 5 단계, 이미지 2/3 Fix a Loose Mounting Dream MD2462 TV Wall Mount: 5 단계, 이미지 3/3
    • Use a pencil to mark three holes on the wall.
    • Use a 3/8-inch drill bit to drill three holes at the marked positions.
    • Secure the wall mount into the wooden studs using new screws or bolts.
    • Ensure that all the screws are firmly secured to the wooden stud.
  6. Fix a Loose Mounting Dream MD2462 TV Wall Mount: 6 단계, 이미지 1/2 Fix a Loose Mounting Dream MD2462 TV Wall Mount: 6 단계, 이미지 2/2
    • Test the firmness of the TV wall mount by gently pushing it up and down.
  7. Fix a Loose Mounting Dream MD2462 TV Wall Mount: 7 단계, 이미지 1/2 Fix a Loose Mounting Dream MD2462 TV Wall Mount: 7 단계, 이미지 2/2
    • Gently replace the TV back on the wall mount.
  8. Fix a Loose Mounting Dream MD2462 TV Wall Mount: 8 단계, 이미지 1/1
    • Make sure the TV is secure and well-centered on the wall mount using a spirit level gauge to confirm the inclination.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Emmanuel Emedeke
회원 가입일: 09/17/20
184 평판
안내서 1개 작성함
York University, Team S2-G6, Melo-Thaiss Fall 2020 York University, Team S2-G6, Melo-Thaiss Fall 2020 회원
YORK-MELO-THAISS-F20S2G6
1 회원
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 49
전체 시간: 5,018
