주요 콘텐츠로 건너뛰기
Fix the MyFirst Camera Insta 2 charge issue
필요한 것
  1. Fix the MyFirst Camera Insta 2 charge issue, Prepare teardown: 1 단계, 이미지 3개 중 1개 Fix the MyFirst Camera Insta 2 charge issue, Prepare teardown: 1 단계, 이미지 3개 중 2개 Fix the MyFirst Camera Insta 2 charge issue, Prepare teardown: 1 단계, 이미지 3개 중 3개
    • Remove SD card, carry strap and paper cartridge
  2. Fix the MyFirst Camera Insta 2 charge issue, Lift the front panel: 2 단계, 이미지 2개 중 1개 Fix the MyFirst Camera Insta 2 charge issue, Lift the front panel: 2 단계, 이미지 2개 중 2개
    • Remove the front panel
    • The panel is simply clipped and can be declipped easily by using a mediator as lever
  3. Fix the MyFirst Camera Insta 2 charge issue, Unscrew front panel: 3 단계, 이미지 2개 중 1개 Fix the MyFirst Camera Insta 2 charge issue, Unscrew front panel: 3 단계, 이미지 2개 중 2개
    • The toy is closed by 5 Philips-head screws, size 0
    • Unscrew them all and open the product
  4. Fix the MyFirst Camera Insta 2 charge issue, Remove the cartridge-holding piece: 4 단계, 이미지 3개 중 1개 Fix the MyFirst Camera Insta 2 charge issue, Remove the cartridge-holding piece: 4 단계, 이미지 3개 중 2개 Fix the MyFirst Camera Insta 2 charge issue, Remove the cartridge-holding piece: 4 단계, 이미지 3개 중 3개
    • The white piece is held by 4 Philips-head screws
    • Unscrew the three screws you can already access
    • Unscrew the selfie camera, held by two smaller screws
    • Under the camera, unscrew the forth screw holding the piece
  5. Fix the MyFirst Camera Insta 2 charge issue, Disconnect the screen: 5 단계, 이미지 1개 중 1개
    • Remove the glue around the screen connector
    • Disconnect by lifting the connector clip upward
  6. Fix the MyFirst Camera Insta 2 charge issue, Unscrew the PCB: 6 단계, 이미지 2개 중 1개 Fix the MyFirst Camera Insta 2 charge issue, Unscrew the PCB: 6 단계, 이미지 2개 중 2개
    • The board is held by the 4 previously removed screws, plus another screw close to USB connector
    • Once all those are removed and the screen is disconnected, pull the card from its compartment by sliding it on the side opposite to USB connector
  7. Fix the MyFirst Camera Insta 2 charge issue, Teardown view: 7 단계, 이미지 3개 중 1개 Fix the MyFirst Camera Insta 2 charge issue, Teardown view: 7 단계, 이미지 3개 중 2개 Fix the MyFirst Camera Insta 2 charge issue, Teardown view: 7 단계, 이미지 3개 중 3개
    • Unknown microcontrolleur, QFP80 package , with reference "2104G-91"
    • Princeton Technology PT5139-HT motor driver
    • Syncrown PT48D 2-inch thermal printer
    • Thinksum 123050 7.4V 750mAh li-ion battery
    • Screen, speaker, two photo modules
  8. Fix the MyFirst Camera Insta 2 charge issue, Fix the MyFirst Camera Insta 2 charge issue: 8 단계, 이미지 1개 중 1개
    • Once the toy is disassembled, replug the battery only and let it charge, with a micro-USB cable
    • Unplug the battery once again before remounting the device
결론
To reassemble your device, follow the unmounting instructions in reverse order.
다음 번역가들에게 특별히 감사 드립니다:
fr en
100%
Eve Redero님은 저희가 세상을 수리하는데 동참하신 분입니다! 기여하시겠습니까?
번역 시작하기 ›
작성자
1다른 기여자 명과 함께
Eve Redero
회원 가입일: 02/28/22
3,101 평판
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 30
전체 시간: 541
