주요 콘텐츠로 건너뛰기
Fix the Short in the Plug Guide
필요한 것
  1. Fix the Short in the Plug Guide, Fix the Short in the Plug Guide: 1 단계, 이미지 1개 중 1개
    • Find the power cord.
    • Make sure that it is unplugged from the outlet. This is to make sure that no power is flowing through and you are not injured.
  2. Fix the Short in the Plug Guide: 2 단계, 이미지 1개 중 1개
    • Locate all exposed portions of the wire.
    • Tape over any exposed portions of the wire with electrical tape.
    • Use this power cord temporarily.
  3. Fix the Short in the Plug Guide: 3 단계, 이미지 1개 중 1개
    • Plug the power cord into the outlet and make sure the power cord is connected to the device. If not, connect the power cord to the back of the device.
    • Replace the damaged cable by purchasing a new cable at your local hardware store.
결승점
작성자
4다른 기여자 명과 함께
Rosana Cheruvelil
회원 가입일: 09/26/12
147 평판
안내서 2개를 작성함
Cal Poly, Team 7-50, Forte Fall 2012 Cal Poly, Team 7-50, Forte Fall 2012 회원
CPSU-FORTE-F12S7G50
5 회원들
안내서 7개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 2
전체 시간: 1,675
