주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Fixed Gear Bike Chainring Replacement
필요한 것
  1. Fixed Gear Bike Chainring Replacement, Chainring: 1 단계, 이미지 2개 중 1개 Fixed Gear Bike Chainring Replacement, Chainring: 1 단계, 이미지 2개 중 2개
    • Slightly loosen the two rear nuts with a 15 mm wrench to give the chain slack.
    • Remove the chain from the worn out chain ring.
  2. Fixed Gear Bike Chainring Replacement: 2 단계, 이미지 2개 중 1개 Fixed Gear Bike Chainring Replacement: 2 단계, 이미지 2개 중 2개
    • Undo all five bolts attached to the crank arm with a hex tool.
  3. Fixed Gear Bike Chainring Replacement: 3 단계, 이미지 2개 중 1개 Fixed Gear Bike Chainring Replacement: 3 단계, 이미지 2개 중 2개
    • Take the chain ring off through the crank arm of the pedal and swap the chainring of your choice.
    • Keep all five bolts in the same area to prevent losing them.
    • When bolts appear to be rusty, I recommend replacing them with a new set of bolts for the longevity of the drivetrain.
  4. Fixed Gear Bike Chainring Replacement: 4 단계, 이미지 1개 중 1개
    • Line up the chainring’s hole to the crankset and tighten all five bolts to hold the chainring in place.
  5. Fixed Gear Bike Chainring Replacement: 5 단계, 이미지 1개 중 1개
    • Lastly, attach the chain back to the new chainring.
    • Before tightening the two rear nuts back together, ensure the wheel is centered and not touching the rear bike frame.
결승점
작성자
1다른 기여자 명과 함께
aljndro__
회원 가입일: 08/22/23
121 평판
안내서 1개를 작성함
CSU Los Angeles, Team 1-1, Briggs Fall 2023 CSU Los Angeles, Team 1-1, Briggs Fall 2023 회원
CSULA-BRIGGS-F23S1G1
6 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 5
지난 30일: 35
전체 시간: 673
