주요 콘텐츠로 건너뛰기
Fixing Epson Stylus Photo 1400 Paper Jam
  1. Fixing Epson Stylus Photo 1400 Paper Jam, Fixing Epson Stylus Photo 1400 Paper Jam: 1 단계, 이미지 2개 중 1개 Fixing Epson Stylus Photo 1400 Paper Jam, Fixing Epson Stylus Photo 1400 Paper Jam: 1 단계, 이미지 2개 중 2개
    • The paper indicator light blinks red if a paper jam occurs. It might have an unusual clicking noise.
    • Press paper button to eject paper.
    • If previous step does not work, turn off the printer and proceed to step 2. Else, proceed to step 4.
  2. Fixing Epson Stylus Photo 1400 Paper Jam: 2 단계, 이미지 1개 중 1개
    • Attempt to remove paper by gently and slowly pulling the paper out from the top.
    • Pull the paper as straight as possible.
    • If this does not work, proceed to step 3. Else, proceed to step 4.
  3. Fixing Epson Stylus Photo 1400 Paper Jam: 3 단계, 이미지 3개 중 1개 Fixing Epson Stylus Photo 1400 Paper Jam: 3 단계, 이미지 3개 중 2개 Fixing Epson Stylus Photo 1400 Paper Jam: 3 단계, 이미지 3개 중 3개
    • Open cover of the printer.
    • Gently pull out the paper through the hatch.
    • If ink cartridge is in the way, gently push it off to the side.
    • Close cover.
  4. Fixing Epson Stylus Photo 1400 Paper Jam: 4 단계, 이미지 1개 중 1개
    • If you had success in step 1, paper indicator light should now return to the normal color green.
    • If you had success in step 2 or 3, turn on printer and press paper button.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Xin Chen
회원 가입일: 10/12/11
1,105 평판
안내서 1개를 작성함
Cal Poly, Team 17-11, Regan Fall 2011 Cal Poly, Team 17-11, Regan Fall 2011 회원
CPSU-REGAN-F11S17G11
4 회원들
안내서 12개를 작성함
댓글 2개
hi my printer(1400) won't print anything whenever I try to print it stacks and then two lights starts blinking on the computer it's saying fetal error paper jam please help me
nkumbu namukoko - 답글
My machine is Epson 1500w ,it make an unusual noise when printing to the middle of the paper and stop lwith the red light blinkinig. Please I need heklp
stephen Banguu-Wobnyine - 답글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 22
지난 30일: 41
전체 시간: 7,082
