소개
This guide will show you how to reset the GLOD.
  1. While the PS3 is on (green LED on), put the PS3 into standby mode (red power LED) by pressing the power button for 5 seconds.
    • While the PS3 is on (green LED on), put the PS3 into standby mode (red power LED) by pressing the power button for 5 seconds.
  2. US$100.00 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
    상점 둘러보기
  3. Now when the PS3 is in standby mode, hold the power button down until you hear it beep about 2 or 3 times, then release the power button.
    • Now when the PS3 is in standby mode, hold the power button down until you hear it beep about 2 or 3 times, then release the power button.
  4. This will reset the video settings to the lowest settings and when you start the PS3 with  HDMI or PS3 AV cable connected, it will go through the setup process and you will now see a picture on the TV screen.
    • This will reset the video settings to the lowest settings and when you start the PS3 with HDMI or PS3 AV cable connected, it will go through the setup process and you will now see a picture on the TV screen.
결승점
다른 62명이 해당 안내서를 완성하였습니다.
Tim Gelvin
회원 가입일: 2010년 11월 02일
3,959 평판
안내서 1개 작성함
Master Techs Master Techs 회원
Community
280 회원들
안내서 783개 작성하였습니다
I have tried this multiple times, even took up a few hints about removing the HDD and putting it back in, and then trying.... it still did not work.... does any one have any idea of how to REALLY fix this?!
codylawinger - 답글
does not work for me i have a slim model. still striving to find a solution.
krn - 답글
I have also been searching endlessly for a solution to this problem for my CECH-2001A model PS3 Slim. The majority of the time my system turns on with the GLOD. The rest of the time it works perfectly. I've tried safe mode and went through all the steps numerous times. I've also tried three different hard drives, two different HDMI cables and two different tv's. None of which alleviate the problem. I've also replaced the thermal paste and am religious with keeping it dust free. The only other solution I've found is that the RSX may be the culprit. Other than that, I'm at a loss.
David - 답글
This does not work for me. I get one beep (on) then one beep (off) then it goes red. I have a CECHL01 model. Still no video. Will a reflow also help HDMI loss?
James - 답글
aww man it did not work for me
StevenSon654 Gaming Channel - 답글
조회 통계:
지난 24시간: 19
지난 7일: 105
지난 30일: 607
전체 시간: 113,406
