필요한 것
open the right side of the Rockwheel's case, the side of the power switch. To access the screws, you need to pull the glued rubber protection a little. Once the case is open you'll see the PCB, the motherboard. You'll need to insert a jumper wire in two right holes on the bottom of the PCB.
거의 끝나갑니다!
결론
다른 6명이 해당 안내서를 완성하였습니다.
