주요 콘텐츠로 건너뛰기
Fixing Sound issues on your Kingston HyperX CloudX
필요한 것
  1. Fixing Sound issues on your Kingston HyperX CloudX, Remove the Microphone: 1 단계, 이미지 1/1
    • Remove the microphone from the left side of the headphones.
    • The microphone is removeable from the headphones themselves and does not require any disassembly
  2. Fixing Sound issues on your Kingston HyperX CloudX, Remove the Memory Foam: 2 단계, 이미지 1/3 Fixing Sound issues on your Kingston HyperX CloudX, Remove the Memory Foam: 2 단계, 이미지 2/3 Fixing Sound issues on your Kingston HyperX CloudX, Remove the Memory Foam: 2 단계, 이미지 3/3
    • Remove the memory foam from the side of the headphones that are giving the audio problem
    • Both sides come off easily! All you have to do is pull the memory foam from the headset and it should come right off.
  3. Fixing Sound issues on your Kingston HyperX CloudX, Unscrew the headphones: 3 단계, 이미지 1/3 Fixing Sound issues on your Kingston HyperX CloudX, Unscrew the headphones: 3 단계, 이미지 2/3 Fixing Sound issues on your Kingston HyperX CloudX, Unscrew the headphones: 3 단계, 이미지 3/3
    • Remove the four 5.0 mm screws located under each memory foam using a Phillips #1 screwdriver.
    • Make sure to hold onto the screws, as you will need them to put the headset back together.
  4. Fixing Sound issues on your Kingston HyperX CloudX, Look for any missing/Broken wires: 4 단계, 이미지 1/2 Fixing Sound issues on your Kingston HyperX CloudX, Look for any missing/Broken wires: 4 단계, 이미지 2/2
    • Look for wires that are missing from the circuit board.
    • For this repair, our headset was missing a green wire so we will solder that back to the board
  5. Fixing Sound issues on your Kingston HyperX CloudX, Solder the missing wire: 5 단계, 이미지 1/1
    • Solder the missing wire back to the headphone's circuit board
결론
Brendan Hopkins
회원 가입일: 10/08/19
133 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 8
30일 전: 33
전체 시간: 2,255
