주요 콘텐츠로 건너뛰기
Fixing a AcuRite Intelli-Time Alarm Clock Faulty Alarm
필요한 것
  1. Fixing a AcuRite Intelli-Time Alarm Clock Faulty Alarm, Opening the Device: 1 단계, 이미지 1/1
    • Flip device upside down and remove the 4 foam pads at each corner.
    • Remove the 4 screws using a Philips Screwdriver.
    • Gently lift the case off of the body and set down in a safe place.
  2. Fixing a AcuRite Intelli-Time Alarm Clock Faulty Alarm, Fixing a AcuRite Intelli-Time Alarm Clock Faulty Alarm: 4 단계, 이미지 1/1
    • Unscrew the 5 screws in the base circuit board.
  3. Fixing a AcuRite Intelli-Time Alarm Clock Faulty Alarm: 5 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Use the tweezers to slightly lift the circuit board, allowing the cylindrical alarm piece to slide out.
  4. Fixing a AcuRite Intelli-Time Alarm Clock Faulty Alarm: 6 단계, 이미지 1/1
    • Check if the wires are secured.
    • If they are not attached, you may re-solder it together. If they are attached, that means it is a faulty alarm and should replace it.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Nicholas Roppolo
회원 가입일: 10/25/13
384 평판
안내서 3개 작성하였습니다
University of Maryland, Team 4-2, Vijaybhaskar Fall 2013 University of Maryland, Team 4-2, Vijaybhaskar Fall 2013 회원
UMD-VIJAYBHASKAR-F13S4G2
2 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 48
전체 시간: 1,369
