주요 콘텐츠로 건너뛰기
Fixing a Broken Shelf in a Refrigerator
필요한 것
  1. Fixing a Broken Shelf in a Refrigerator, Fixing a Broken Shelf in a Refrigerator: 1 단계, 이미지 2개 중 1개 Fixing a Broken Shelf in a Refrigerator, Fixing a Broken Shelf in a Refrigerator: 1 단계, 이미지 2개 중 2개
    • Open the refrigerator door.
    • Empty any items on the shelf bar.
  2. Fixing a Broken Shelf in a Refrigerator: 2 단계, 이미지 2개 중 1개 Fixing a Broken Shelf in a Refrigerator: 2 단계, 이미지 2개 중 2개
    • Grasp the shelf on each end and lift each straight up.
    • Disengage the two hooks from the molded tabs on the liner.
    • Inspect to make sure they are not damaged.
  3. Fixing a Broken Shelf in a Refrigerator: 3 단계, 이미지 2개 중 1개 Fixing a Broken Shelf in a Refrigerator: 3 단계, 이미지 2개 중 2개
    • Remove any tape that was holding the shelf bar together.
  4. Fixing a Broken Shelf in a Refrigerator: 4 단계, 이미지 1개 중 1개
    • Clean the shelf using dish detergent and water.
    • Remove any tape residue with a scouring pad.
  5. Fixing a Broken Shelf in a Refrigerator: 5 단계, 이미지 1개 중 1개
    • Take a paper towel or towel and dry off the shelf bar.
  6. Fixing a Broken Shelf in a Refrigerator: 6 단계, 이미지 1개 중 1개
    • Try fitting the pieces together to make sure that the pieces are intact and that nothing is missing.
  7. Fixing a Broken Shelf in a Refrigerator: 7 단계, 이미지 1개 중 1개
    • Spread the Loctite 60 Sec Universal glue along the edge of both sides of the bar.
  8. Fixing a Broken Shelf in a Refrigerator: 8 단계, 이미지 2개 중 1개 Fixing a Broken Shelf in a Refrigerator: 8 단계, 이미지 2개 중 2개
    • Carefully join the pieces together and hold them tight for two minutes.
    • Tape the pieces together with blue painter’s tape.
    • The tape comes off easily without leaving any gluey residue.
  9. Fixing a Broken Shelf in a Refrigerator: 9 단계, 이미지 1개 중 1개
    • Leave the shelf to dry for ten minutes.
    • Once the glue dries, take the blue painter’s tape off.
  10. Fixing a Broken Shelf in a Refrigerator: 10 단계, 이미지 2개 중 1개 Fixing a Broken Shelf in a Refrigerator: 10 단계, 이미지 2개 중 2개
    • Take the shelf bar and line the hooks over the tabs and press it firmly back into the refrigerator door.
    • Do not place too much pressure on the shelf, so it won't crack again.
결론
After completing all the steps for repairing the refrigerator shelf bar, the refrigerator shelf bar will be all new. However, be gentle with the shelf bar. Do not place much pressure on it or it will break again.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Tatiana Jeune
회원 가입일: 01/12/19
217 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 14
지난 30일: 60
전체 시간: 11,609
