주요 콘텐츠로 건너뛰기
Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler
필요한 것
  1. Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler, Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: 1 단계, 이미지 1/3 Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler, Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: 1 단계, 이미지 2/3 Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler, Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: 1 단계, 이미지 3/3
    • Turn your label-maker on its face. Using your thumb, press in and then upward on the fastener located on the side of your device.
  2. Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: 2 단계, 이미지 1/3 Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: 2 단계, 이미지 2/3 Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: 2 단계, 이미지 3/3
    • Remove the batteries from your device.
  3. Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: 3 단계, 이미지 1/3 Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: 3 단계, 이미지 2/3 Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: 3 단계, 이미지 3/3
    • Using a plastic opening tool from your iFixit tool kit, leverage the label cartridge out of your device.
  4. Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: 4 단계, 이미지 1/3 Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: 4 단계, 이미지 2/3 Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: 4 단계, 이미지 3/3
    • Press the label paper back into alignment with the small holders on the right side of the label cartridge.
  5. Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: 5 단계, 이미지 1/3 Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: 5 단계, 이미지 2/3 Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: 5 단계, 이미지 3/3
    • Place the label cartridge and batteries back into your device. Refasten the bottom case of the label-maker.
  6. Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: 6 단계, 이미지 1/3 Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: 6 단계, 이미지 2/3 Fixing a Jammed Paper-Roll in your Brother PT-90 Personal Labeler: 6 단계, 이미지 3/3
    • Well done! You have successfully corrected the paper-jam in your Brother PT-90 Label-Maker.
결론
Kaitlyn Abrams
회원 가입일: 10/13/16
1 평판
안내서 1개 작성함
University of Maine, Team 2-1, Diaz Fall 2016 University of Maine, Team 2-1, Diaz Fall 2016 회원
UMAINE-DIAZ-F16S2G1
3 회원들
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 4
전체 시간: 784
