주요 콘텐츠로 건너뛰기
Fixing a Small Animal Cage Ladder
필요한 것
  1. Fixing a Small Animal Cage Ladder, Replacing the Rope for a Small Animal Cage Ladder: 1 단계, 이미지 1/1
    • Take your ladder out of the pet’s cage and lay it out to clearly assess the damage.
  2. Fixing a Small Animal Cage Ladder: 2 단계, 이미지 1/3 Fixing a Small Animal Cage Ladder: 2 단계, 이미지 2/3 Fixing a Small Animal Cage Ladder: 2 단계, 이미지 3/3
    • Gather your supplies for the fix (ie: new rope, scissors, ruler, sewing kit, clips). These items will be used to fix the small ladder.
  3. Fixing a Small Animal Cage Ladder: 3 단계, 이미지 1/2 Fixing a Small Animal Cage Ladder: 3 단계, 이미지 2/2
    • Cut the old rope in the ladder with scissors and pull it out of the cylindrical wood pieces.
    • Make sure the knots at the ends of the rope are cut. This will enable you to pull the rope out easily.
  4. Fixing a Small Animal Cage Ladder: 4 단계, 이미지 1/1
    • Measure your new rope to the length of the ladder using a ruler.
  5. Fixing a Small Animal Cage Ladder: 5 단계, 이미지 1/1
    • Begin pushing rope through the individual holes in the wood pieces (use a sewing kit if necessary).
    • If there is the need to use a sewing kit to drag the rope through the wood here is how to do so: Push the needle through the end of the rope and tie a knot around the rope. Once you are finished with this, push the needle through the rope holes and then sew the rope through the individual pieces.
  6. Fixing a Small Animal Cage Ladder: 6 단계, 이미지 1/1
    • Once all the rope has connected the wood into a ladder, tie knots at each end to keep the pieces together.
  7. Fixing a Small Animal Cage Ladder: 7 단계, 이미지 1/1
    • Add clips to the ends of the rope and attach to the small animal cage.
    • If the clips cannot attach to the rope, tie the rope around the clips.
결론
Katrina Hartmann
회원 가입일: 03/03/18
145 평판
안내서 1개 작성함
USF Sarasota-Manatee, Team S1-G1, Stewart Spring 2018 USF Sarasota-Manatee, Team S1-G1, Stewart Spring 2018 회원
USFSM-STEWART-S18S1G1
15 회원들
안내서 25개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 19
전체 시간: 319
