주요 콘텐츠로 건너뛰기
Fixing a Wobbly Armrest on the VonRacer Gaming Chair
필요한 것
  1. Fixing a Wobbly Armrest on the VonRacer Gaming Chair, Fixing a Wobbly Armrest on the VonRacer Gaming Chair: 1 단계, 이미지 1/3 Fixing a Wobbly Armrest on the VonRacer Gaming Chair, Fixing a Wobbly Armrest on the VonRacer Gaming Chair: 1 단계, 이미지 2/3 Fixing a Wobbly Armrest on the VonRacer Gaming Chair, Fixing a Wobbly Armrest on the VonRacer Gaming Chair: 1 단계, 이미지 3/3
    • To be able to reach the bolts on the bottom of the seat in an easily accessible manner, you should pull out the leg rest and recline the seat all the way back.
    • After doing so, put the chair on its side.
    • This is recommended to be able to have an easier time removing the screws.
  2. Fixing a Wobbly Armrest on the VonRacer Gaming Chair: 2 단계, 이미지 1/3 Fixing a Wobbly Armrest on the VonRacer Gaming Chair: 2 단계, 이미지 2/3 Fixing a Wobbly Armrest on the VonRacer Gaming Chair: 2 단계, 이미지 3/3
    • Remove the two 25 mm arm rest bolts with an M8 hex screwdriver.
    • Remove the arm rest.
  3. Fixing a Wobbly Armrest on the VonRacer Gaming Chair: 3 단계, 이미지 1/3 Fixing a Wobbly Armrest on the VonRacer Gaming Chair: 3 단계, 이미지 2/3 Fixing a Wobbly Armrest on the VonRacer Gaming Chair: 3 단계, 이미지 3/3
    • Tighten the three screws on the arm rest, one for the elbow joint and two for the arm rest cushion, with a Phillips #1 screwdriver.
    • Give the arm rest a shake to ensure there is no wobble in the two joints.
  4. Fixing a Wobbly Armrest on the VonRacer Gaming Chair: 4 단계, 이미지 1/3 Fixing a Wobbly Armrest on the VonRacer Gaming Chair: 4 단계, 이미지 2/3 Fixing a Wobbly Armrest on the VonRacer Gaming Chair: 4 단계, 이미지 3/3
    • Align the arm rest with the two screw holes on the bottom of the seat.
    • Replace the two 25 mm M8 hex screws to secure the arm rest.
    • Be sure to sufficiently tighten these screws to eliminate any wobble.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Abdullahi Hassan
회원 가입일: 09/21/20
133 평판
안내서 1개 작성함
York University, Team S1-G8, Woodhouse Fall 2020 York University, Team S1-G8, Woodhouse Fall 2020 회원
YORK-WOODHOUSE-F20S1G8
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 5
7일 전: 13
30일 전: 73
전체 시간: 13,672
