주요 콘텐츠로 건너뛰기
Fixing the Automatic Reverse Flipping of a Cassette-to-Aux Adaptor
필요한 것
  1. Fixing the Automatic Reverse Flipping of a Cassette-to-Aux Adaptor, Fixing the Automatic Reverse Flipping of a Cassette-to-Aux Adaptor: 1 단계, 이미지 3개 중 1개 Fixing the Automatic Reverse Flipping of a Cassette-to-Aux Adaptor, Fixing the Automatic Reverse Flipping of a Cassette-to-Aux Adaptor: 1 단계, 이미지 3개 중 2개 Fixing the Automatic Reverse Flipping of a Cassette-to-Aux Adaptor, Fixing the Automatic Reverse Flipping of a Cassette-to-Aux Adaptor: 1 단계, 이미지 3개 중 3개
    • Remove the six screws around the cassette tape box.
    • Place the screws somewhere safe so you do not lose them.
    • Models, screw locations, and screw sizes may vary.
  2. Fixing the Automatic Reverse Flipping of a Cassette-to-Aux Adaptor: 2 단계, 이미지 3개 중 1개 Fixing the Automatic Reverse Flipping of a Cassette-to-Aux Adaptor: 2 단계, 이미지 3개 중 2개 Fixing the Automatic Reverse Flipping of a Cassette-to-Aux Adaptor: 2 단계, 이미지 3개 중 3개
    • Slowly remove the cover of the cassette box.
    • Take a photo of the insides of the cassette box so it can guide when you are reassembling the cassette box.
    • Do not worry if you open the cassette box upside down (shown in 2nd photo) it is easy to correct; simply put the case back on, flip it over (shown in 3rd photo) and pull the new front side off (1st photo again).
  3. Fixing the Automatic Reverse Flipping of a Cassette-to-Aux Adaptor: 3 단계, 이미지 2개 중 1개 Fixing the Automatic Reverse Flipping of a Cassette-to-Aux Adaptor: 3 단계, 이미지 2개 중 2개
    • Remove the auto flip mechanism located on the top corner.
    • Do not throw this away; you may have to reinstall it if you want to use a different cassette player.
  4. Fixing the Automatic Reverse Flipping of a Cassette-to-Aux Adaptor: 4 단계, 이미지 2개 중 1개 Fixing the Automatic Reverse Flipping of a Cassette-to-Aux Adaptor: 4 단계, 이미지 2개 중 2개
    • Make sure all electrical circuitry and gears that were not removed are in their correct location.
    • Any other gears inside the cassette box, really aren't necessary. So feel free to remove them if the cassette is making too much noise (shown in 2nd photo).
    • Edit 3/14/2019: All cars are different. Many people in the comments have had luck keeping the center gears in the cassette and removing the interface gears. And also vice versa. Play around with it! If you can get it to work, awesome! If not, then try something else. Don't give up until you have your music playing in your car! Cheers!
결론
To reassemble your device, follow these instructions in reverse order, but do not replace the gears you removed.
다른 18명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Jonathan Falco
회원 가입일: 02/24/15
756 평판
안내서 2개를 작성함
29가이드 댓글
that $@$* done work all it did was keep swtiching sides even more without the gears in it.............
pvmxfgt - 답글
It might have to do with the stereo in your car. When I made this guide, I was experiencing the problem in my 2000 Nissan Xterra, but my own guide didn’t help. Some stereos are just broken, like mine was. To be completely honest, I had no idea this guide would even work for people, like it is. Sorry it didn’t help fix your problem. I would suggest getting a new stereo installed in your car. If it’s an older car, you may be able to do it <$100 for a decent stereo. Cheers mate!
Jonathan Falco -
Worked perfectly for me, thanks for putting this guide together.
Patrick Osborne - 답글
You’re welcome!
Jonathan Falco -
Worked for me. I used to buy these things new every couple of years. Glad I did not throw all the old ones out
Peter K - 답글
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 26
지난 30일: 180
전체 시간: 88,039
