주요 콘텐츠로 건너뛰기
Flash and re-install the firmware of TCA Yoke
필요한 것
    • Download and install the driver package from here.
    • TCA Yoke and TCA Quadrant both use the same driver.
    • Press on the Windows button and type "Firmware Update" into the search.
    • Unplug your TCA Yoke from USB port if you already have it plugged-in
  1. Flash and re-install the firmware of TCA Yoke, Press and hold the XBOX button: 4 단계, 이미지 1개 중 1개
    • Press and hold the Xbox button.
    • Make sure to set your Yoke into PC mode, using the switch at the back, before proceeding to the next step.
  2. Flash and re-install the firmware of TCA Yoke, Connect to USB while holding the Xbox button: 5 단계, 이미지 1개 중 1개
    • Keep holding the Xbox button and connect the Yoke to USB port.
    • Once connected, wait a few seconds and let go of the button.
    • Your TCA Yoke should show up in Firmware Updater.
    • Press OK on the Firmware Updater and wait for update to complete.
결승점
작성자
1다른 기여자 명과 함께
Formica Fusca
회원 가입일: 08/01/24
2,595 평판
안내서 15개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 7
지난 30일: 35
전체 시간: 309
