주요 콘텐츠로 건너뛰기
Flashforge Finder 2 Fan Cleaning or Replacement
필요한 것
  1. Flashforge Finder 2 Fan Cleaning or Replacement, Work safely: 1 단계, 이미지 1개 중 1개
    • Shut down the back switch and disconnect the printer power supply
    • If used recently wait for the extruder to cool down
  2. Flashforge Finder 2 Fan Cleaning or Replacement, Remove extruder cover: 2 단계, 이미지 3개 중 1개 Flashforge Finder 2 Fan Cleaning or Replacement, Remove extruder cover: 2 단계, 이미지 3개 중 2개 Flashforge Finder 2 Fan Cleaning or Replacement, Remove extruder cover: 2 단계, 이미지 3개 중 3개
    • Remove the three screws on the extruder top with a 2.5 Allen key or an appropriate screwdriver bit
    • Gently lift up the extruder cover
    • Pay attention to the flat cable while lifting the cover
  3. Flashforge Finder 2 Fan Cleaning or Replacement, Disconnect the fan: 3 단계, 이미지 1개 중 1개
    • Using a spudger, disconnect the fan connector
    • Route the cable to free it
  4. Flashforge Finder 2 Fan Cleaning or Replacement, Unscrew the fan: 4 단계, 이미지 2개 중 1개 Flashforge Finder 2 Fan Cleaning or Replacement, Unscrew the fan: 4 단계, 이미지 2개 중 2개
    • Remove the two Phillips screw holding the fan
  5. Flashforge Finder 2 Fan Cleaning or Replacement, (Optional) Disassemble the fan: 5 단계, 이미지 2개 중 1개 Flashforge Finder 2 Fan Cleaning or Replacement, (Optional) Disassemble the fan: 5 단계, 이미지 2개 중 2개
    • The fan can now be removed from the extruder. If you need to replace it, just follow the steps in reverse order with the new fan
    • If you are cleaning the fan, release the three clips holding it together with a spudger
  6. Flashforge Finder 2 Fan Cleaning or Replacement, Clean the fan: 6 단계, 이미지 1개 중 1개
    • Using compressed air and a brush, clean the fan from dust and debris
결론
작성자
1다른 기여자 명과 함께
dinoo_fixit
회원 가입일: 03/22/22
1,706 평판
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 15
전체 시간: 228
