주요 콘텐츠로 건너뛰기
Fleetwood Monarch 62" Recurve Bow String Replacement
필요한 것
  1. Fleetwood Monarch 62" Recurve Bow String Replacement, String: 1 단계, 이미지 1/1
    • Remove the broken or damaged bow string.
  2. Fleetwood Monarch 62" Recurve Bow String Replacement: 2 단계, 이미지 1/1
    • One end of the new bowstring will have a loop with a larger diameter than the other. Take the larger loop and secure it onto one end of the bow.
  3. Fleetwood Monarch 62" Recurve Bow String Replacement: 3 단계, 이미지 1/1
    • Slide the larger loop halfway down the limb of the bow.
  4. Fleetwood Monarch 62" Recurve Bow String Replacement: 4 단계, 이미지 1/1
    • Secure the smaller loop onto the other end of the bow.
  5. Fleetwood Monarch 62" Recurve Bow String Replacement: 5 단계, 이미지 1/3 Fleetwood Monarch 62" Recurve Bow String Replacement: 5 단계, 이미지 2/3 Fleetwood Monarch 62" Recurve Bow String Replacement: 5 단계, 이미지 3/3
    • Place your left leg between the bow shaft and the bow string.
    • Place your foot behind the end of the bow touching the ground.
    • Place one hand near the middle of the bow and the other hand on the string, close to the larger loop.
    • Push down on the top end of the bow and slide the larger loop into place.
결론
Enjoy your new bow-string!
다른 한 분이 해당 안내서를 완성하였습니다.
Zachery Kail
회원 가입일: 09/16/20
121 평판
안내서 1개 작성함
University of Memphis, Team 51-3, Willis Spring 2022 University of Memphis, Team 51-3, Willis Spring 2022 회원
UM-WILLIS-S22S51G3
1 회원
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 20
전체 시간: 695
