주요 콘텐츠로 건너뛰기
Flip MinoHD USB Port Replacement
필요한 것
  1. Flip MinoHD USB Port Replacement, Battery: 1 단계, 이미지 1/2 Flip MinoHD USB Port Replacement, Battery: 1 단계, 이미지 2/2
    • With the Phillips screwdriver 000, unscrew the two small screws securing the battery to the outer case and set safely aside.
    • With the plastic opening tool, pry the battery out of device and set aside. Now the battery is fully removed.
  2. Flip MinoHD USB Port Replacement, USB Port: 2 단계, 이미지 1/3 Flip MinoHD USB Port Replacement, USB Port: 2 단계, 이미지 2/3 Flip MinoHD USB Port Replacement, USB Port: 2 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Using Phillips screwdriver 000, unscrew the 4 screws from the outer casing. Now the small white microphone should disconnect and is free to be set aside.
    • With Phillips screwdriver 000, unscrew the 3 screws which secure the aluminum USB bracket.
    • Using tweezers, remove the USB port from the device. Your device is now a skeleton and is ready for replacement. To do so, follow these steps backwards.
결론
Abigail Buckenberger
회원 가입일: 01/06/16
720 평판
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 10
전체 시간: 511
