이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
This guide will show you how to replace the camera lens of your Flip Video.
필요한 것
Remove the 3 5mm screws securing the circuit board to the front shell with the #00 Phillips screwdriver.
With the LCD screen facing away from you, remove the 2 bronze 3 mm screws securing the LCD using the #00 Phillips screwdriver.
Flip over circuit board so the ribbon connector is facing up.
Remove the 2 stainless steel 3mm screws securing the lens to circuit board with the #00 Phillips screwdriver.
다른 한 분이 해당 안내서를 완성하였습니다.
