주요 콘텐츠로 건너뛰기
Flip Video Ultra Camera lense Replacement
필요한 것
  1. Flip Video Ultra Camera lense Replacement, Circuit Board: 1 단계, 이미지 1/1
    • Unlock the battery cover by sliding the switch to the unlock position.
  2. Flip Video Ultra Camera lense Replacement: 2 단계, 이미지 1/1
    • Remove the battery cover by sliding it down the camera.
  3. Flip Video Ultra Camera lense Replacement: 3 단계, 이미지 1/1
    • Remove the batteries
  4. Flip Video Ultra Camera lense Replacement: 4 단계, 이미지 1/1
    • Slide the black upper casing off from the device.
  5. Flip Video Ultra Camera lense Replacement: 5 단계, 이미지 1/2 Flip Video Ultra Camera lense Replacement: 5 단계, 이미지 2/2
    • Remove the six 1mm screws from the back and upper casing with the Phillips Head screwdriver.
  6. Flip Video Ultra Camera lense Replacement: 6 단계, 이미지 1/1
    • Remove the top casing from the bottom to reveal the inner circuit board.
  7. Flip Video Ultra Camera lense Replacement: 7 단계, 이미지 1/2 Flip Video Ultra Camera lense Replacement: 7 단계, 이미지 2/2
    • When removing the back panel, the rubber buttons will become loose and likely fall off the board. This is normal and can easily placed back on the board once finished.
    • Remove the six 1mm screws with the 1 Phillips head screwdriver.
  8. Flip Video Ultra Camera lense Replacement: 8 단계, 이미지 1/1
    • Gently separate the circuit board from the casing.
  9. Flip Video Ultra Camera lense Replacement: 9 단계, 이미지 1/2 Flip Video Ultra Camera lense Replacement: 9 단계, 이미지 2/2
    • Unscrew the single 1mm screw from USB housing unit.
  10. Flip Video Ultra Camera lense Replacement: 10 단계, 이미지 1/2 Flip Video Ultra Camera lense Replacement: 10 단계, 이미지 2/2
    • Unscrew the 2 1mm screws and gently separate camera wires from plastic casing.
  11. Flip Video Ultra Camera lense Replacement: 11 단계, 이미지 1/1
    • Gently pry out the USB housing unit with the Ifxit Opening Tool.
  12. Flip Video Ultra Camera lense Replacement: 12 단계, 이미지 1/3 Flip Video Ultra Camera lense Replacement: 12 단계, 이미지 2/3 Flip Video Ultra Camera lense Replacement: 12 단계, 이미지 3/3
    • Remove the two 1mm screws and separate the circuit board and camera from the plastic casing.
  13. Flip Video Ultra Camera lense Replacement: 13 단계, 이미지 1/1
    • Unscrew the camera housing unit from the plastic case.
  14. Flip Video Ultra Camera lense Replacement: 14 단계, 이미지 1/3 Flip Video Ultra Camera lense Replacement: 14 단계, 이미지 2/3 Flip Video Ultra Camera lense Replacement: 14 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • With tweezers, remove the microphone and USB connections.
  15. Flip Video Ultra Camera lense Replacement: 15 단계, 이미지 1/2 Flip Video Ultra Camera lense Replacement: 15 단계, 이미지 2/2
    • Unscrew the two 1mm screws from the board shown. Remove screen from circuit board.
  16. Flip Video Ultra Camera lense Replacement: 16 단계, 이미지 1/2 Flip Video Ultra Camera lense Replacement: 16 단계, 이미지 2/2
    • Remove the single 2.1 mm screw and separate camera from the circuit board.
  17. Flip Video Ultra Camera lense Replacement, Camera lense: 17 단계, 이미지 1/1
    • Camera lens is now separated from the circuit board.
결론
Nathaniel Ruf
회원 가입일: 10/18/16
514 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team 5-7, Martin Fall 2016 UMass Dartmouth, Team 5-7, Martin Fall 2016 회원
UMASSD-MARTIN-F16S5G7
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 4
전체 시간: 229
